Question about Whirlpool Dishwashers
I have a Whirlpool Quiet Partner II with flashing lights: pots & Pans, Normal, Clean and Start all at the same time! The Normal. dry. normal.dry trick hasn't worked. Can u suggest something else?
Posted by Rich Crump on
David Byrne
    Habit-Forming:
  • 112 Answers
Unplug it count to ten, plug it back in.
It may just need to reset...
Posted on Apr 03, 2016
My whirlpool quiet partner II imperial series Dishwasher will only work on light wash mode. Normal wash, heavy wash or pots and pans cycle will not work at all.
This is ordinarily a problem with the touchpad. Can you give me the specific model number of yours (ordinarily on a sticker on the inside edge of the door or on the door opening)?
Mar 06, 2016 | Whirlpool Dishwashers
Gold Quiet Partner lll. Why are lights flashing on normal, pots and pans, and cancel?
I had this happen and I was unable to cancel, so I believe I resolved it by flipping the breaker off, then back on, and it's been working fine for a several years since then. Your electric panel should have a separate switch/fuse for the dishwasher. Some have a plug under the sink, but most are "hardwired". Cheers.
Dec 26, 2015 | Whirlpool Dishwashers
Whirlpool Quiet partner V Dishwasher will not start no lights ,,,nothing
Try unlatched door and hit heated dry, normal, heated dry, normal all within 3 seconds of each ither. Close dior, latch and try again.
Mar 02, 2015 | Whirlpool Gold Series Quiet Partner Iv...
Whirlpool Quiet Wash II
there might be connection problem with those buttons you've tried
Jun 04, 2013 | Dishwashers
Does my whirlpol du1145xtpb1 dishwasherr need to be reset
SERVICE DIAGNOSTICS CYCLE
To start the Service Diagnostics Cycle, press the
following keys, in order, in less than 6 seconds, while in standby(power on but unit off):
Heated Dry, Normal, Heated Dry, Normal
To Rapid advance one interval at a time, press the Start key, noting that
unlike Standard cycles, the Diagnostics Cycle automatically resumes
after door openings and does not require pressing Start to resume.
Once the diagnostic cycle has run and shut off, run a normal wash cycle, empty and with no detergent, to reset the control to factory "normal" operation. Make sure there's plenty of hot water.
Read more: http://forum.appliancepartspros.com/dishwasher-repair/261055-whirlpool-quiet-partner-ii-clean-light-flashing-have-reset-still-flashing.html#ixzz2UOcsE2Yg
May 25, 2013 | Whirlpool 24 in. GU3200XTP Built-in...
I have a whirlpool quiet partner II dishwasher model # DU1055XTVB5 and the normal light is steady flashing I have did the sequence to reset HEATED DRY NORMAL HEATED DRY NORMAL and the normal light...
Angelia:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, [email protected], with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
Mar 06, 2018 | Whirlpool 24 in. DU1055XTP Built-in...
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner 980
Bad control board ,replace it.
May 26, 2008 | Dishwashers
Whirlpool dishwasher # quiet partner II
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
Jan 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
460 people viewed this question
Top Whirlpool Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
