Question about Jura Capresso Impressa E8 Espresso/Coffee Maker
How to remove and replace water lid on E8
Hinge broke off
Posted by Randy Peters on
Edward Harris
    Scholar:
    New Friend:
  • 78 Answers
The hooks in the lid are tricky to remove without breaking. It is best to remove the top cover. To do so you need special key to open the machine. Order the special key from the link below.
Watch the video posted on You tube channel "Parts Guru USA".
Descale the machine every three months using manual descaling.
Jura instructions are misleading and create unnecessary error messages. Services Unlimited Inc Parts Guru Since 1988 Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Posted on Oct 23, 2016
Scanner lid hinge broken or missing
If you read through the posts, there are many ideas on what to do. The cheapest and easiest way I found to fix a broken hinge is to follow one the ideas in the posts. I wrote a detailed post step-by-step. In quick summary, I broke the other hinge and removed all the broken pieces to both, so the lid would lay flat again. Printer doesn't care if the hinges are not there. The manual is on line:http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=3635378 Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
Apr 01, 2014 | HP Officejet 6700 Premium E-All-In-One
Scvs605a slow cooker hinged lid replacement
Great news !
Think I found a place for you in Canada that carries the hinged lid for your model
it's $15.99
http://www.crock-pot.ca/en_CA/parts/crock-pot-slow-cooker-hinge-lid/7921000031743.html
happy cooking
Dec 05, 2017 | Rival SCVS605A Slow Cooker
Lid stuck
That lever is part of a hinge assembly - if the hinge has broke (and from your question it seems that it is) you have to literally de-case your laptop to remove the hinge assembly in order to replace it.
Jul 30, 2013 | Dell LATITUDE Computers & Internet
How do I replace lid assembly for Whirlpool WTW8800YC 4.6 Cu. Ft. Cabrio Platinum Top Load Washer
Hi Sarah, there are two screws on each side of the lid holding the shaft for the hinges. Open the lid to access them, You will need an Allen wrench to take them off, after that, just lift the lid up to take it out. Hope this help. Thanks.
Feb 23, 2013 | Whirlpool WTW8800YC 4.6 cu. ft. Cabrio...
Washing machine stops mid-cycle, water doesn't drain
Sounds like you have a bad lid switch, or the plastic plunger on the lid that engages the lid switch is broke. if the plunger is broke, it is cheap, and only 2 screws to remove and put new one on. if that is not broke, check the lid switch. This model is a lid switch, and lid lock in one. You can test it before replacing it if you have a meter. you need to hinge the lid up to check and replace the lid switch. use a putty knife, on each side between the top and top of the front panel. slide the putty knife in one side, it will hit a bracket if your in the right spot. press in, and lift on that side of the top. do the same on other side, just don't let go of the first side or it will latch again. then swing the top back, the back side is on hinges. the lid switch is on the right side attached to the top. unplug washer, remove the 2 wires on the switch and check continuity. there should be continuity, or "open" when the lid is closed, and no continuity, or "closed" when you open the lid. if it is "closed" even when lid is closed, replace the lid switch. let me know if you have any further questions, shane.
Sep 12, 2009 | Washing Machines
Hinges for top cover for HP officejet 6210- Q5820A
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
Sep 06, 2009 | HP Officejet J5780 All-In-One Printer
Lid support broke
Not much info but if you mean the lid on your DS falls backward when opened then one of two things has happened either the small barrel lock in the hinge has broken, this is rare. Or you have broken the hinge allowing the barrel lock to rotate in the case.
The barrel is cheap and a very easy fix by opening the case removing the led lens holder then change the lock. If you have broken the hinge you will need to replace the case, tricky job requiring patience especially when transfering the top screen to the new case. Watch a few you tube instruction videos to get a better idea of whats involved.
Jun 10, 2009 | Nintendo DS Lite Console
Gateway left hinge broke
Definately an easy fix.
I suggest looking on eBay for a donor chassis.
Sometimes they can be had relatively cheap CLICK HERE (this one has both hinges broken however) - and sometimes just the parts you are looking for are available CLICK HERE (this is for the RHS one though).
An entire donor PC is adviseable, because usually the repair is not just the hinge that broke - as the rest of the lid is plastic!
Once the trim above the keyboard is pried off, you will see the monitor cable, and hinge screws.
The trim around the monitor must be dis-assembled and pried into 2 parts.
Then the hinge & Support are either screwed into the side of the screen, or the back of the lid.
Most look like this...
Replace reverse of removal.
HERE is a link that will describe it better and give you a visual reference.
You are interested in step #s 7, 8, 11, 12
Once the screen is free of the chassis - its time to remove the little rubber scerw covers in the lid, and disassemble.
Good Luck!! Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 02, 2009 | Gateway MX6448 Notebook
ESTATE WASHER
ck lid switch earlier modes had switch on right of lid opening later it was moved to left rear hinge area ..those on right just replace those on left first ck hinge screws on left be sure they are secure listen for click when closing lid..no click raise lid push on hinge arm on left side toward rear of washer slightly try again still nothing remove console screws on rear of console lift and roll console back ck switch on left side may be broken if so replace
Sep 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Jura Capresso Impressa E8 Espresso/Coffee Maker Logo
100 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
