Question about Garden
I some how lost my primer fuel line and have a hole in the gas tank I cant find the nipple to put into the hole to attach the fuel line
The round hole that the fuel line connects to is missing a nipple or is it a fuel filter imn not sure it is the line that runs from primer
Posted by Chris Hamilton on
Frank Back
    New Friend:
On my Atom edger the return line from the primer bulb goes directly into the fuel tank through the hole in the bottom of the tank.
-There is no connector for this.
-Cut the end of this fuel line at a sharp angle and insert it into the tank, push it in about 3 cm and then fit the other end of the line to the primer bulb.
-The tight fit that a new fuel line gives is sufficient to seal the entry hole and my does not leak when using a fresh/new fuel line.
Posted on Oct 16, 2016
Plink-plonk
  • 1,807 Answers
Make and model of the tool will aid people in answering your question.
Posted on Apr 03, 2016
How to replace fuel lines on Poulan P3314
I am asuming you are already into the saw and looking at the carb and tank. There are two fuel lines, one gets gas to the carb, the other returns gas to the tank. The 'in' fuel line has to be long enough so you can pull it out the gas fill hole to attach the filter and to rest on the bottom of the tank. (The weight of the filter will keep it on the bottom.) The 'out' line only has to be long enough to go into the tank but not vibrate out. Both should be fairly snug in their holes so gas won't leak out around them. Either line can go through either hole in the tank however, one hole is usually easier for each line to run in without kinking. If you don't know which nipple is which on the carb, put one end of a line on one nipple and the other end in some gas and pump the primer. If it sucks gas up, it's the 'in' nipple, if not it's the 'out' nipple. If you got the 'out' nipple, be sure to check the other to make sure the primer is working properly.
Feb 22, 2012 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Need a diagram for installing new gas lines on craftsman weed eater model no.358.797101.I wanted to put new lines on but lost my train of thought.The hose ends were leaking due to age.
I don't have a diagram, but I can give you detailed instructions. Hopefully this will get your "train of thought" back on the right track.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
May 17, 2011 | Craftsman Garden
Where does the second gas line connect to on a mcculloch m32em leaf blower?
Feb 22, 2011 | McCulloch 26cc Gas Backpack Blower Dual...
HOW TO ROUTE NEW GAS LINES ON RYOBI31CC,15:,CURVED SHAFT 700R,,,THANK YOU CHARLIE
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for 1/2" or so.
Feb 09, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Gas lines crumbled and don't know how to route new lines correctly
Dec 12, 2010 | Weedeater Gas Blower
Fuel system gas tank supply setup line connetions
Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb.If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank
Oct 05, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
No gas getting from the gas tank to the carb. replaced hoses and filter already. can not even draw gas with primer button.
You either need a new primer bulb (leaking air) or you have the fuel lines routed wrong. Here is the correct fuel line routing just in case:
Oct 04, 2010 | Craftsman Convertible 25cc. Gas Line...
Need diagram for fuel line in tank fuel filter
The small diameter fuel line that has the fuel filter in the tank on it goes directly to the carburetor (with the built-in primer or externally mounted primer). IF the carb has the external primer, the small line goes to the nipple on the carburetor opposite the end with the hole in the cover. If it has the built-in primer on it, it goes to the carb body on the nipple furthest from the bulb. The large diameter line is the fuel return line and if the carb has the bulb on it, this line connects on the nipple closest to primer bulb.. With the externally mounted primer, this line connects on the longest nipple coming out of the primer and goes to the fuel tank (not the filter though). There is a nylon connector inside the tank that holds this larger line in place. The shorter nipple on primer bulb has a smaller diameter fuel line connected to it and connects to the nipple on the carb closest to the end with the hole in the cover. Built in primer has 2 fuel lines...externally mounted has 3.
Jul 31, 2010 | Craftsman 25cc Gas Line Trimmer
McCulloch 3216 fuel primer and gas tubes routing?
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Nov 01, 2009 | McCulloch Garden
Garden Logo
172 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
