Question about Magellan RoadMate GPS
No power, was working and now nothing happenning
Posted by julius muinde on
1helpful
Electrolux dryer edi97170w died while working over night power ok but nothing happens on display
You might want to post this in the washer/dryer section. This is currently listed in the vacuum section
Car won't start, seems to have power, all lights working. when I turn the key nothing happens. this only happens sometimes
Could be a bad alternator.. It may not be holding charge. Or your starter could have failed.
Though I've had the same problem and it was a dead battery in my vehicle. Had enough power, but to keep the car on..
1helpful
No power at all
Check the capacitors in the power supply, check for any bulged tops. Your problem is most likely power supply related.
1helpful
I have a compaq 6820,s and it won't power up, i get nothing, no screen, sound power, nothing at all. I change the power cord and nothing happen. So could anyone out there help me please?
Try reseating the RAM modules, If this does not work then the RAM maybe faulty. Remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. If the RAM is faulty them it needs to be replaced.
My hard drive wont read it worked before dont know why
A disk-drive has several major components:
* the electronics circuit-board
* the power/data external connectors
* the motor that spins the disk-drive
* the read/write mechanism that moves above the recording surface
* the recording surfaces
No power means no "spin", and nothing happens.
Dead motor means no "spin", and nothing happens.
Dead electronics on the circuit-board means that nothing happens.
Damaged read/write mechanism.
Damaged recording surfaces.
4helpful
3answers
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
1helpful
MSI K9A2 CF motherboard powers up, but nothing happens
try to get into the bios and see if the function of the power switch assigned differently. there are MB that use the a hotkey in the keyboard to power-up the system. It should be there in bios. Read the MB's manual too. On OFF state, try typing "O" and "N" then hit enter
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
1helpful
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
GPS Logo
Top Magellan GPS Experts
Ekse
Oloyede Monsuru
Are you a Magellan GPS Expert? Answer questions, earn points and help others
