To close the garage door I just push the button , but to close the garage door I have to hold the button down until the door closes what's wrong
The garage door seems to open with the push of my button , but close the door I have to hold on to the button until the garage door is completely closed,
Adjust the position of the door by using the black and purple
buttons. Black moves the door UP (open) and purple moves
the door DOWN (close)
Setting the up position:
1. Press and hold the black button until the LED starts flashing
slowly, then release.
2. Push and hold the black button until the door reaches the
desired UP (open) position
3. Push the door control or programmed remote control. This
sets the Up (open) position and begins closing the door.
4. Immediately when the door begins to close press and release
the black or purple button. This will stop the door
Setting the Down position:
5. Push and hold the purple button until the door reaches the
desired DOWN (Closed) position.
6. Once the door is closed, If there appears to be too much
pressure on the door, you may toggle the door back and forth
using the black and purple buttons to reach the desired closed
position.
7. Push the door control or programmed remote control. This
sets the Down (closed) limit and the door should open.
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
You have a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not blinking. Also check the wiring.
IF U HAVE TWO EYE,SENSORS ON EACH SIDE OF THE DOOR SEE IF SOMETHING IS BLOCKING THE EYES OR SOETHING IS COVERING THEM, OR THEY ARE OUT OF ALIGNMENT, ONE SHOULD SHOW GREEN, AND ONE RED EYE, GOOD LOCK
