Question about Hisense 50 Class 1080p LED Smart HDTV - 1920 x 1080, 120Hz, 2000000:1 Dynamic, 4x HDMI, Built-in Wi-Fi 50K610GW-RB - 50K610GW-RB
50" Hisense Led/Lcd smart tv with sound but no picture.
I replaced the Led driver board first then the T-con board then the power supply board and still no fix.
3 Related Answers
dduncan774
David Duncan
  • 760 Answers
SOURCE: My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Posted on Mar 20, 2013
gopakumarg43
  • 76365 Answers
SOURCE: hisense LED TV are not coming on and my power supply are 100% but my t-con board have no power and no pic and back light pleas help me model is LEDN50K20DGP/C1Z1
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Dec 12, 2014
enquiries83820
George
  • 132 Answers
SOURCE: On my Hisense 50K23DG LED TV, I have sound but no picture.
Hisense TV's usually use PCB Boards by Vestel and not Hisense themselves, have a look at: Vestel Help If the Boards in your Hisense match this Board/Part Number format at least you'll know what to search for, replacing the power supply will not help unless the process has been incorporated into the power supply and that is not known for certain yet
Good Hunting
Posted on Jan 13, 2016
My TV is a LG 47LN5700-UH I had a lightning strike near the house. Afterward TV would start but not boot completely. Now it won't start at all. Cable box also got fried at the same time.
The led driver AND the T-con board are bad. If you could see a picture with the flashlight then the T-con board would be good. It is not. The led driver can be on the main board or the power supply board. You can get these parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 14, 2018 | LG Televison & Video
Where is led driver located on Westinghouse DW39F1Y1
I don't have a service manual for your set but I believe the LED driver is part of the power board, did you test the voltage going to the LED panel?
Nov 16, 2017 | Westinghouse Televison & Video
The answer to my question was to replace the T-Con Board. Looking at Shop Jimmy the only board for this model is BN44-00801E Power Supply/LED Driver Board. Is the T-Con board embedded in this board?
The T-Con board is embedded in the main board and not in the power supply/LED Driver board.
The Main board part number should be BN94-09124C but I would suggest to do more research or call Samsung for more info.
Sep 18, 2017 | Samsung Televison & Video
How do I fix a Samsung UN32EH5300FXZA LED TV with a blank screen, but with backlights and sound working?
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board..
Nov 21, 2016 | Samsung Televison & Video
Help fixing my tv
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jul 22, 2016 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
I have a 50" element tv. Model # ELEFT502 The picture went black but sound still works. when u take a flashlight to it u can still see the picture. Easy fix??? Also where/how much would the part be?!
http://electro-medical.blogspot.com/
Jan 11, 2016 | Element Televison & Video
Samsung LED TV (UN39FH5000FXZA) has audio, but does not have backlight. I replaced the power supply/ LED board with no success, could this be caused by the main board or the t-con board?
Hi Matt,
The fault lies with the backlight LEDs. It is common with these sets. If you open the panel and replace the failed LEDs, or replace the panei.
Good luck.
Dec 05, 2015 | Samsung 5000 Series UN39FH5000 39" LED TV...
Open Questions:
See all Hisense 50 Class 1080p LED Smart HDTV - 1920 x Questions
Hisense 50 Class 1080p LED Smart HDTV - 1920 x 1080, 120Hz, 2000000:1 Dynamic, 4x HDMI, Built-in Wi-Fi 50K610GW-RB - 50K610GW-RB Logo
409 people viewed this question
Top Hisense Televison & Video Experts
Sean Burke
Sean Burke
David Tickner
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
