Question about Watches
First thing to check is for locks that are put in when shipping so that it wont be damaged. If it is battery powered, check the battery.
Posted on Apr 02, 2016
SOURCE: What ports wind what?
On mine, the center one (@the 6 position) is the one that keeps the pendulum swinging. It is the one that lengthens the most during the week and if I forget to wind it, that pendulum is all the way down when the clock stops.
Posted on May 02, 2009
SOURCE: The pendulum stopped swinging...the clock and
Hi
This clock short of needing a full service may simply be out of beat.
Taken from my web page located at:
http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
"HOW TO PUT YOUR CLOCK IN BEAT"
-Included below is a 10-second sound <snip> of a clock both in and out of beat.
IN BEAT ////////\\\\ OUT OF BEAT
· Turn on your sound and click on the clocks above for a sound clip.
-One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
-I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
-As I'm sure we now realize a clock must be in beat but not always level to function properly.
· Above is the verge with a slip clutch.
· Often found on Grandfather clocks and requires only a long swing to get it in beat.
-To get the clock on the right side in beat you would need to push the verge assembly to the left.
-If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
R/ David
Posted on Jan 21, 2010
SOURCE: We recently purchased a Howard Miller Grandfather
Just taking a stab that someone replaced the suspension spring with one that is too long, and beyond the pendulum adjustment.
Posted on Oct 25, 2010
SOURCE: How to syncronize time with
The hands on your clock are probably friction fit, meaning that they can be adjusted, possibly even without tools. The hour hand is usually a firm slip fit over a tube, meaning that it can be slid forward and backward an hour or more as long as you hold the minute hand steady to keep the hour shaft from turning.
The minute hand may be trickier to adjust. Sometimes, it, too, is a simple friction fit, and you can pop off the hand (remove the second hand and pull the minute hand straight up off its shaft) before setting it where it should go. Other times, however, the minute hand is on a keyed shaft and has to go on in one of two directions. It's still possible that someone could have assembled your clock incorrectly, however, making the minute hand 30 minutes out of sync with your chimes.
If neither of these ideas helps you, please describe better exactly how the time isn't matching up with the chimes. That will help us better understand the underlying issue.
Posted on May 10, 2011
SOURCE: pendulum will not stay swinging on mantle clock
check out the link below
http://www.youtube.com/watch?v=ps6dPxoxe9c
Posted on Jul 26, 2012
Dec 06, 2016 | The Watches
Jan 16, 2018 | Howard Miller Watches
Jan 01, 2011 | Watches
Aug 03, 2010 | Watches
Jan 28, 2010 | Watches
Sep 07, 2009 | Watches
May 02, 2009 | Watches
99 people viewed this question
