Question about Carrier Heating & Cooling
I have a carrier window ac error coad 5a flashing for some time ac not on
Posted by Abdul ahamad on
Max
    New Friend:
Its probably not 5A but SA. And SA means sleep auto it activates on pressing the energy saving button on remote. Its not an error but a feature.
Posted on Jun 28, 2016
My carrier ac is showing cl when we on it . Is there a problem
It's a filter clean reminder please see picture attached to resolve the problem.
Mar 03, 2018 | Carrier Heating & Cooling
I have a window carrier ac 1.5 ton. display show 5A what is this
Its not 5A but SA means energy saver mode.use remote to change to cool mode without energy saver.
Sep 09, 2016 | Carrier Heating & Cooling
What tha mining of cl coad for carrier split a.c
Hi Sir. My carrier inverter AC starting on time in Display showing code CL what is the problem but how to solved that problem
Jun 04, 2016 | Carrier Heating & Cooling
Fuse Box Diagrams (Inside and Engine) for 2009 Volkswagen Tigua?
Attached are the diagrams requested - good luck!
Fascia 1
Fuse, (Amps), Circuit
F1 -
F2 -
F3 -
F4 -
F5 -
F6 -
F7 -
F8 -
F9 (5A) Supplementary restraint system (SRS) control module
F10 (10A) Four wheel drive control module
F11 (5A) Parking aid control module, self-parking system control module
F12 (10A) Gas discharge headlamp control module (LH)
F13 (5A)
ABS/ESP system, AC system, anti-dazzle interior mirror, heated windscreen washer jets, seat occupation control
module, transmission control module (TCM), reversing lamps, engine management system
F14 (10A)
ABS control module, engine control module (ECM), heated seats, power steering control module, suspension
control module, trailer control module, AC control module, instrumentation control module, CAN data bus
gateway control module
F15 (10A)
Auxiliary heater, data link connector (DLC), parking brake control module, engine management, headlamp
direction control module
F16 (10A) Gas discharge headlamp control module (RH)
F17 (5A) Instrument panel
F18 (10A) Mobile telephone control module, multimedia control module
F19 (10A) Steering column function control module 2
F20 (5A) ABS control module, AC system, transmission control module (TCM)
F21 (15A) Door function control module, left rear, door function control module, right rear, multifunction control module 2
F22 (5A) Alarm system, multifunction control module 2
F23 (10A) ABS/ESP system, AC system, data link connector (DLC), rear view camera control module, headlamp switch
F24 (10A) Door function control module, driver, door function control module, passenger
F25 (20A) Transmission control module (TCM)
F26 -
F27 -
F28 (40A) AC control module, auxiliary heater
F29 (15A) Rear screen wiper motor
F30 -
F31 (20A) Auxiliary power sockets, cigarette lighter
F32 -
F33 -
F34 -
F35 -
F36 -
F37 -
F38 (10A) Steering column function control module 1
F39 (20A) Headlamp washers
F40 (15A) Trailer control module
F41 (15A) Trailer control module
F42 (20A) Trailer control module
F43 (25A) Sunroof control module
F44 (25A) Parking brake control module
F45 (25A) Heater blower motor, heated rear window
F46 (30A) Door function control module, driver, door function control module, passenger
F47 (30A) Door function control module, driver, door function control module, right rear
F48 (15A) Fuel pump (FP)
F49 (20A) multifunction control module 2
F50 (25A) Parking brake control module
F51 (40A) AC/heater blower motor control module
F52 (30A) Seat heater control module
F53
(20A/30A)
Headlamp washers
F54 (30A) Auxiliary power sockets
F55 (15A) Lumbar support adjustment
F56 (15A) Suspension control module
F57 (25A) Sun blind control module
F58 (1A) Trailer warning lamp
F59 (20A) Multimedia control module
F60 -
Fascia 3
in engine bay
Fuse (Amps) Circuit
F1 -
F2 -
F3 (5A) Multifunction control module 2
F4 (30A) ABS/ESP system
F5 -
F6 (5A) Instrumentation control module, steering column function control module 2
F7 (40A) Ignition main circuits
F8 (25A) In-car entertainment (ICE)
F8 (25A) Voltage converter
F9 (5A) Mobile telephone control module
F10 (5A/10A) Engine control module (ECM)
F11 (20A) Auxiliary heater control module
F12 (5A) CAN data bus gateway control module
F13 (15A/30A) Engine control module (ECM)
F14 (5A) Engine management system
F15 (5A/10A/15A) Fuel pump (FP), AC compressor clutch, engine management system
F16 (30A) Multifunction control module 2
F17 (15A) Alarm system horn
F18 (30A) Audio system
F19 (30A) Windscreen wiper motor
F20 (10A) Engine management system
F21 (10A/20A) Engine management system, fuel pump (FP) control module
F22 (5A) Clutch pedal position (CPP) switch
F23 (10A) Engine management system
F24 (10A) Engine coolant blower motor control module, engine management system, engine coolant heater
F25 (40A) ABS/ESP system
F26 (30A) Multifunction control module 2
F27 -
F28 (50A) Glow plug control module
F29 (50A) Electric seats
F30 (50A) Ignition switch circuits
Location Component
1 Petrol: Engine control (EC) relay 1
1 Diesel: Ignition main circuits relay
2 Petrol: Engine control (EC) relay 2
2 Diesel: Engine control (EC) relay
Nov 26, 2014 | 2009 Volkswagen Tiguan
Flashing cf after carrier ac turns off
Here is an Article that I found that has some useful information for you. http://airmaster.net/troubleshooting/carrier-window-room-air-conditioner-troubleshooting CF means Cooling Fail.
Check us out online at AC Services Boca Raton
Mar 12, 2012 | Carrier Heating & Cooling
Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
POWER LIGHT FLASHES 5 TIMES CARRIER SPLIT SYSTEM 42PI00H
carrier split ac blinking 5 times & stop the unit
Sep 03, 2009 | Carrier Heating & Cooling
1995 chrysler lebaron
Here's what mine says- for a 95 Chysler LeBaron GTC Convertible. I didn't see anything about a fuel pump, but maybe it's connected to something else? I dunno. Good luck. Here's the info at least.
1 HTR-AC 30A, 2 POWER WINDOWS 30A C/B, 3 PWR SEAT, LKS, TOP 30 A C/B, 4-BLANK, 5 BACK-UP LAMPS 20A, 6 TURN SIGNAL 20A, 7 REAR WIPER 20A, 8 ILLUM LAMPS 5A, 9 INTERIOR LAMPS 10A, 11 CIGAR LIGHTER 20A, 12 RS AMO 20A, 13 INTERIOR LAMPS 10A. 14 BOD COMP MESS CTR 5A, 15 SPEED CONTROL 2A, 16 GAUGES AIRBAGS 5A, 17 STOP LAMPS 18 HEAD LAMP RT-LOW 10A, 19 HEATED MIRRORS 5A, 20 AIRBAGS 5A, 21 STOP LAMOS 20A, 22 HORN 20A, 23 RT-TAIL LAMP-EUR 5A, 24 LT-TAIL LAMP EUR 5A, 25 HEAD LAMP LT-HI 10A, 26 HEAD LAMP RT-HI 10A, 27 RADIO 104, 28 FRONT WIPER 20A
Mar 29, 2009 | 1995 Chrysler LeBaron
Heating & Cooling Logo
1,707 people viewed this question
Top Carrier Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Marvin
Marvin
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
