Garden Logo
g
graeme noble Posted on Apr 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace the pull starter cord - Garden
L Pfaff
Level 3:
Top Expert:
  • Master 11,573 Answers
  • Posted on Apr 01, 2016
L Pfaff
Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3585026
Points
181713
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
2answers
Briggs 10 hp. When pull to start, cord will sometimes snap back hard enough to pull out of your hand. Does it less on choke. Mag gap is ok. Flywheel key is straight and new plug. Any thoughts? Thanks
There are a few potential causes for the starter cord snapping back and pulling out of your hand on a Briggs 10 horsepower engine:
  1. Weak starter spring: The starter spring may be weak or broken, causing the cord to snap back with more force.
  2. Worn starter pulley: The starter pulley may be worn or damaged, causing the cord to slip or bind when pulling it.
  3. Worn starter cord: The starter cord itself may be worn or damaged, causing it to snap back with more force.
  4. Clogged carburetor: A clogged carburetor can cause the engine to run poorly, making it harder to start and causing the starter cord to snap back with more force.
To fix the issue, you can try replacing the starter spring, starter pulley, or starter cord as needed. You can also try cleaning the carburetor to see if this helps. If the problem persists, it is recommended to have a mechanic or small engine repair technician take a look at the engine to diagnose and repair the issue.
How can I replace starter pull cord?
Hi James:
Replacing any starter cord is usually a matter of removing the pull start assembly, pulling the cord until it is completely unwound, block the reel so it cannot retract, remove the old cord, (remember EXACTLY how it was connected), install a new cord, unblock the reel so it can retract, re-install the assembly.
It may be necessary to remove covers or engine shrouds to get to the pull start assembly. That's part of the fun of "do-it-yourself".
Cheers..
How do I replace a pull cord for pm 605 mcculloch chainsaw?
First remove the pull starter housing.
The next part is tricky. You'll have to release and unwind the spring that rewinds the pull starter cord. Remember how you do this because after replacing the cord, you'll have to rewind the cord and spring before inserting it back in the housing.
re-attach the pull cord housing to the chain saw.
Hope this helps.
1helpful
How to put a new pull rope on it How do I put a new pull rope on
It realy depends on what model we are talking about, so i will give a general disciption, remove the four screws retaining the starter to the saw, remove the starter, if the cord is still under tention, pull the starter handle out approx 8", whilst held out hold the pulley to stop it retracting, let go the starter handle and unwind the now lose cord from around the pulley, once enough cord has been unwound let the pulley slowly turn until all the spring tention has gone, remove the center fixing screw, and remove the pulley, pull the old cord away, refit a new suitable diameter cord, knot the end and pull the cord into the pulley so as the knot sits flush into the hole in the pulley, wind the cord fully around the pulley,now refit the pulley to the cover, refit the centre screw ,push the other end of the cord through the cover eyelet and refit the starter handle with a suitable knot, now wind the cord around the pulley a further two times by turning the pulley and winding up the spring, allow the spring to pull the cord in, if required wind the pulley a further turn until the cord is suitably tentioned in the cover, replace the cover on the machine, pull the cord out to make sure it has engaged fully into the pawls before fully tightening the fixing screws.
The pull string will not pull out to start the
Remove the starter mechanism from the saw and try to turn the flywheel--it should turn freely except when the piston is rising against compression. If ok, pull the starter cord and watch for twisted cord or a damaged/split spool. Try to turn the spool CW by hand to see if it is bound up by something. Was the starter cord just replaced? If so, maybe the return spring was over-wound and can't be turned further. Hope this helps!
2answers
Pull cord broke on my lawn boy mower,new cord won't retract??
I don't know exactly what you have there, but starters in general work pretty much the same. What you have to do with any starter when you replace the rope is to first wind up the spring with the pulley. Turn the pulley in the direction it would be turning if you were pulling the rope. When it's wound tight, back off to align the rope hole in the cover and the pulley. Stick the rope from the outside through the cover and pulley and tie a knot. Then let the spring tension pull the rope into the starter. Hope that helps. Dwain
Jul 16, 2009 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
