I was wondering if it is ok to refreeze freezer as there is a probe open to the frosting.
That's just a beauty factor (mostly)...
Almost immediately peeled off of my kitchen-aid...
Insise... No problem.
I was told if water IS NOT FROSTING up on it... It will be fine.
If water IS frosting... OUTSIDE THE REFRIGERATOR....
the dripping can create lots of issues.
Place clean sheet of typing paper... just like checking those valves under the sink. Wait a few days.. check THAT paper.
No drops = everything is great.
Drops means you need to put some decent insulating
wrap around the tubing to keep MOIST AIR from direct contact..
ELSE ... don't worry about inside refrigerator frost. Designed to handle & drain away water .
(my opinion... NO problem (I'm pretty vigilant about my wife's intake ... keeping toxins to a low roar (she's a keeper)))...
The brazing and tubing materials have not been TOXIC since lead piping days (decades ... wrong... generations ago)...
Good to be thoughtful about these things!!
SOURCE: small frigidaire with very small freezer completely fill with frost
Most of the smaller freezers are not self de-frosting, Im not certain about the one you have but usually the only way is to unplug them and let them thaw out for a few hours. Make sure to put towels down to absorb the water or you may have a mess.
SOURCE: Water does not drain from the Freezer during the defrost cycle
hi thanks for the question the drain hose goes to the underneath by the compressor thaw out the freezer and clean the drain hose this will solve the problem thanks the appliance doc
SOURCE: fan continuously running, non-stop
hi thanks for the question its normal for a frost free freezer to run a long time to keep a good cold temp i don't think you have a problem thanks the appliance doc
SOURCE: Frost buildup around the inside top of the door of
This happens when your thermistor gets frozen along with the coils or there is a clogging of the freezer drain which causes Ice to build up and spread to the system. Another issue is that your thermistor may be faulty, telling the system inaccurate temperature. Incorrect freon pressure can also be a cause. I would advise first to have the ice melted by letting the unit stay unplugged and have it cleaned while at it.
stopped up drain,tear in gasket,not going into defrost soon enough
