I changed the spark plugs and check the carb.and clean and check the air Filter,can you help me with this problem?
If it runs good at half throttle, it just wont throttle up it sounds like the throttle cable has slipped. you might try to adjust it to get full throttle back .but if when you turn it up to full throttle and it dies then you have a choke, carburetor, fuel line, fuel filter or fuel tank problem. hope this gives you an idea.
Testimonial: "Thank " Jim Flower,Here is what I found so fur problem number 1(Rock arm off the intake push Rod, )problem 2(Stuck Value,) problem 3(Values Out of adjustment,) problem 4(Blow Head Gastis,)Here is my solusion to the problems(1 check all the values lash--Both Intake and Exhush Values,--(intake value should, be 0.004 in)--(The Exhaust Value,should be 0.006 in) if the rock arm is off the push rob,(Frist-Take out all spake plugs for the next step,(To Check -to Make"
