SOURCE: what size bolt do i
Metric M5 or M6 from HD or LOWES for about 35 cents each.
Get different length to try.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
SOURCE: I LOST THE SCREWS OF MY TABLE TOP STAND OF MY
Read the informations of those screws to tighten the tv and the base stand together.Read it in ur owner manual for those exactly screws sizes.Standard screws tvs sizes for a 46" are screw (M4 X L16).
SOURCE: what size bolts do i use to mount it
It is very likely that the correct mounting bolts to attach a wall mount to your TV are type M8 bolts 20 MM long. It is a rather standard size and you should be able to find them locally without a problem. This is the most probable size although you may find that it requires a different size. It should be either a M5 or M4 bolt of similar length. Give it a try, I think you will find it works perfectly!
SOURCE: What size bolts attach tv to stand for Toshiba 37"
You will use the bolts that you take out to remove the base from the tv.
There
are three common sizes for billiard tables. 3.5 On 7, 4 on 8 and 4.5 on 9. The
table width should be half the size of its overall length. If you watching
billiard tournament on TV you probably wonder why the tables look so big, most
cases you would be right because in tournaments they use the 9 feet tables and
most pool sellers supplies up to 8 feet table.
