I have a vhs video tape that won't play. I would like to move the tape to another case but there are no screws in the 5 holes. Just looks like a tab of some kind. How can I get the case apart?
Hi. Why is my VHS tape playing fast?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px; transform: rotateZ(-180deg);">
If you have a VHS video tape that's playing too quickly then it's very likely that the player you are using does not support either LP or SLP. SLP capable video players should automatically detect the mode and adjust automatically.
or try this link out.
https://www.manchestervideo.com/2017/09/15/faq-why-do-some-video-tapes-play-too-quickly/
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
if VHS tape is in you have only one solution..to disassemble DVD/VCR ..Can you do it ? you may try !!t
Here's how to do it.. * 1 Turn off the COMBO. and unplug it. * 2 Remove the
4x screws off COMBO on the sides and take off the DVD/VCR casing. * 3 Look for the Tape which messed up with VCR transport mechanism ,try to release tape of the transport with your hand..
* 4 Since EJECT feature works with power only ,while you keep the
tape off from transport plug the device to power and turn it on..Don't
worry,you will see the eject mechanism starts moving back on forth,keep
the tape off it and let it eject..
* 5.When tape is out .If it
destroyed badly normally you should not use it however if the recording
in is valuable for you you can cut the chewed portion and splice it back together .(Pls see the video included...How to fix a broken VHS tape.) * 6 While it is open,place another Tape to see if mechanism works properly. and eject it... * 7 Replace the casing and the screws. Plug the player in and turn it on. Now player is finally working .. Hope this helps!.. Take care and please Remember to rate/vote and give us 4 Thumbs Up to continue for Helping out the Community :) http://www.youtube.com/watch?v=Q1PJWA2KGyg
If you remove the screws and very carefully lift off the bottom half of the case you should fine the contents should stay in place. Then its just a case of removing the twist and replacing the case half.
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
How old is the VHS tape? I've had success recording older movies, but the newer ones have encryption to prevent duplication of them. I've even tried playing them on another VCR and transmitting the signal with a wireless audio/video transmitter but unfortunately the encryption is still there. If you can copy the tape to another tape, then it may not have encryption. If that's the case, check you A/V inputs to see if you have them setup right.
Yes! The cheapest way to fix it is to buy a new blank tape and take it apart transplant the old tape & reels to the new case of the new tape. Be sure to keep your fingers off the surface of the tape.
I get the same problem with one tape (it's about 20 minutes long) .. it also shows a '4' ... when you press the power button it ejects the tape... some tapes are fine ...
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter.
There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR:
1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology.
2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly.
3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds.
4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly.
5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
