What causes an E01 error code on the CT Electric Cooktop control panel?
CT E01
STEPS TO VERIFY ISSUE:
Turn the home circuit breaker to the unit off for 30 seconds then back on again. Then retest the unit operation.Or contact the maker direct. They are expensive units and in my experience, if you get 2 years out of them in a commercial setting, you are lucky!
E01 error code. Drained hot tub, unhooked green egg. Ran hose into the two filter pipes and back flushed the pump. Plugged back in and it works fine now.
Different manufacturers use different codes, as I am sure you have figured out. Most of them that I have run into E-01 means the inside and outside units are not communicating. One is without power or there is a broken or loose wire.
E01 on jvc camcorder means that camcorder could not finish loading operation and switch to next mode for more then 4 sec. Usually, timing of the mechanism is out of order or mode switch is faulty. Overhaul of the mechanism plus full alignment is required.
If you are still seeing the EO1 error code, turn over the display panel and see if there is a RED light next to a set of letters. Whatever the light is next to, that would be the cause of the error code.
E01 means Mechanism has not fully loaded up to the stop position
E06 meansTape drive motor is not rotating or stalled.
Thses two faults indicate a tape jam. please remove the cassette and insert a new cassette.
