Question about Motorola Mobility MOTOMING A1200 Smartphone - Flip Intel XScale312 MHz - 8 MB - 2.4" LCD 240 x 320 - 2 Megapixel Camera - Quad Band - Bluetooth - USB - 7.40 Hour Talk Time
Need a full body housing - Motorola Mobility MOTOMING A1200 Smartphone - Flip Intel XScale312 MHz - 8 MB - 2.4" LCD 240 x 320 - 2 Megapixel Camera - Quad Band - Bluetooth - USB - 7.40 Hour Talk Time
  • Official Brand Answer
  • 1,623 Answers
Hi Rudhra g,
Please, you can check online, some sites will have them for sale.
Best regards,
Suny
Motorola Support
Posted on Apr 25, 2016
Where do ifind acrilic paints
if for painting a house and you need large cans of the stuff
hardware and paint supply businesses
if a budding artist or body painter and need it in tubes
hobby and craft stores or full on art supply stores
in our part of the world you can get some from dollar shops
Mar 08, 2017 | Miscellaneous
SWITHCHES ON OK BUT IS NOT TAKING IN WATER ALTHOUGH FULLY CONNECTED TO WATER SUPPLY
You possibly have a bad water inlet valve. It is the electric valve that the house water line connects to. Usually a plastic body with 2 wires going to it. Shut off house water supply before disconnecting it. Another possibility is what is called the Flood switch. There should be a dome float in one of the corners. If the dishwasher gets too full of water that will rise and activate a switch to turn off the water. It may be stuck in the up position acting like the dishwasher is over full.
Mar 24, 2015 | Dishwashers
Engine diagram 1997 buick skylark/thermostat
follow the water inlet pipe to water pump the thermostat housing connects to water pump this is for 2.4l engine you have to remove exhaust manifold heat shield.you will see the water inlet pipe going to water pump inlet thermostat housing.for the 3.1 engine follow top radiator hose to thermostat housing you have to remove air filter air duct and filter housing , you have to remove throttle body unit with coolant hoses, you have to disconnect accelerator cable, transmission down shift cables at the bracket bolts to throttle body.once you remove throttle body unit then you can see and remove the thermostat housing to replace thermostat.you need to buy new throttle body gasket,and new small coolant hoses connects to the throttle body unit.have extra gallon antifreeze dexcool on hand.
Nov 15, 2011 | Cars & Trucks
Change thermostat on 2004 chevy impala?
first you need drain engine coolant down below thermostat. what engine type 3.8 or 3.4 need to know.the 3.8 engine thermostat housing on top intake follow top radiator hose to thermostat housing.the 3.4 engine you have to remove air filter housing with air inlet duct with mass air flow sensor.you have to remove throttle body with coolant hoses.go to auto parts store buy new throttle body hoses old ones will be hard to remove might have to cut two small hoses also buy new throttle body gasket also. before you can remove throttle body unit you have to remove accelerator cable and downshift cable from bracket bolted to throttle body.once throttle body remove then you can remove thermostat housing bolt remove replace thermostat.
Nov 11, 2011 | 2004 Chevrolet Impala
Its body is loose n old. i want a new body for my phone
Visit the eBay..pleaty of available..Here is one example..
Take care and pls do not forget to rate me too
Regards
Ebay item number:160483593684 Black Full Housing Cover Case For HTC P3300http://cgi.ebay.com/Black-Full-Housing-Cover-Case-HTC-P3300-Dopod-P800-/160483593684?pt=LH_DefaultDomain_0&hash=item255d914dd4
Jun 15, 2011 | HTC P3300 Smartphone
I own a impala 2003 and i would like to know how to change the thermostat on it.The motor is a 3.4 liters
Drain radiator. Remove upper rad hose from thermostat housing. Disconnect air intake hose from throttle body. Remove throttle body from upper intake manifold, disconnecting the 2 rubber hoses to the heater line. You may also need to disconnect the fuel line. Remove the exhaust crossover heat shield and loosen the crossover pipe from both exhaust manifolds but don't remove crossover completely. You should have access to the 2 thermostat housing bolts, remove upper bolt but just loosen the lower one about a half inch. Pull the housing out and up from the intake manifold to access the thermostat. Clean the mating surfaces with a gasket remover. replace thermostat, apply a light coating of rtv sealant to both sides of the new gasket. Replace thermostat housing with the gasket to the intake manifold. Apply some rtv to the bolt threads before reattaching housing. Tighten bolts snugly but do not over tighten. Tighten exhaust crossover and reattach the heat shield. Install throttle body attaching the 2 little hoses at the bottom, its a good time to replace these hoses and clamps. Depending on the condition of the throttle body gasket you may need to replace it also. Reconnect the fuel line (if disconnected) Reconnect air intake hose to throttle body. Reattach the upper rad hose to housing. Fill rad with coolant 50/50 mix with water (make sure to use the same type antifreeze that is in the system, they say you can mix green with red but I wouldn't recommend) Leave rad cap off start the car and let it warm up until you can see the coolant circulating and ad coolant as necessary until full. Now there is going to be some air in the system that you need to bleed out. There are 2 bleeders on this system, 1 is on the top of the thermostat housing, and the other is on the metal heater line on top of the water pump (the one that goes across the front of the engine and around under the throttle body that the two little hoses attach to) Bleed the one on the housing first (its the lower one) open it until fluid comes out then tighten it. Then move to the 1 on the heater line(above water pump) loosen it until fluid comes out the re-tighten. Fill recovery tank to fill line replace the rad cap and take it for a ride, watching the temp gage closely. If the temp goes higher than normal than there is probably more air in the system. you'll have to bleed it again.
This is a very labor intensive procedure and I do recommend buying or checking a service manual out from your local library. I've done these in the past and to be honest I just have the dealer do it now. A system flush and thermostat replacement was around $230 the last time I had it done, but it comes with a warranty. And you wont have to rent or buy a fuel line disconnect tool if you end up having to disconnect it. These are the hardest thermostats I've ever replaced.
Jun 09, 2010 | 2003 Chevrolet Impala
How do I know if the transmission is slipping or if I just need to replace gear shaft
I recently did a full tune-up on a friends VW jetta. He drove it for quiet a while with the (feels like the transmission slipping) By cleaning the throttle body, it helped it to shift better. It can be cleaned by removing the Air filter and housing, Spray Throttle body cleaner into it with the throttle open. Wipe clean with a none shedding rag. Repeat the process. The cleaner dries fast, but let the car sit for a few minutes. Put housing and filter back on. It may seem hard to start after, it's because the cleaner. it's no big deal. Unless You rather for the VW dealership do it for around $300.
Dec 31, 2009 | 1999 Volkswagen Beetle
Where is the thermostat housing on a 1006 Buick Regal?
The thermostat in the 3.1 engine is in the thermostat housing. Follow the upper radiator hose towards the engine, where the hose connects to the engine is the thermostat housing which leads under the throttle body. Yup, it's not the easiest thing to get to unless you have small hands and a few socketextensions and swivel. If you have small hands you can remove the thermostat housing without removing the throttle body. Just remove cross over exhaust heat shield to give you enough room to get the socket with an extension and swivel to the two bolts to the thermostat housing under the throttle body. Remove front bolt and the second one just needs to be loosen and you can wiggle out the thermostat housing to replace the thermostat. If you need more room, your going to have to remove the throttle body and replace the throttle body gasket also to give you more room to get the thermostat housing out. Good luck and hope this helps and take care not to damage the temperature sensor on the manifold just in front of the housing. Keep me posted if you have any more questions and take your time.
Jul 15, 2009 | 1996 Buick Regal Olympic Gold
2001 V Tech engine runs full throttle in neutral or in gear
Look under the hood. Look for the throttle body .The accelerator cable is attached to it. The cable housing anchor is broken and not letting it return to idle speed.. Use a portion of a clothes hanger to
secure the cable housing to the throttle body.
Apr 04, 2009 | 2001 Mercury Sable
Motorola Mobility MOTOMING A1200 Smartphone - Flip Intel XScale312 MHz - 8 MB - 2.4" LCD 240 x 320 - 2 Megapixel Camera - Quad Band - Bluetooth - USB - 7.40 Hour Talk Time Logo
46 people viewed this question
Top Motorola Mobility Cell Phones Experts
Lawrence Oravetz
Vernon Taylor
Harrie
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
