Question about Toshiba Office Equipment & Supplies
Sir, Toshiba 356 I instal new toner but machine not working.message coming instal new black toner what can I do
Posted by Rajeev Vrindavan on
kasun fernando
    Wolfpack:
    An expert that has 5 followers.
  • Toshiba Expert
  • 253 Answers
Need original toner. this one is cannot refill
Posted on Jun 26, 2016
5 Related Answers
Anonymous
SOURCE: toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Posted on Mar 19, 2008
Anonymous
SOURCE: Add Black Toner Msg.
Thanks Ricohman for the suggestion. Toner was original Ricoh cartridge and reinstalling it didn't help. I decided to tear the machine apart and discovered the auger for the black toner was stuck. I removed the auger, cleaned everything up and put the machine back together. Works great now.
Posted on Jul 14, 2008
Anonymous
SOURCE: replace waste toner container message
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
Posted on Apr 17, 2009
romsky79
rommel dadulla
  • 822 Answers
SOURCE: Toner low we installed new toner. then message
remove plastic cover from toner yellow or any color and install toner properly.
Posted on Jun 04, 2009
Anonymous
  • 86 Answers
SOURCE: BROTHER MFC 7820N MACHINE PUT IN NEW DRUM, CHANGE
To manually reset the counters, do the following:
  • Open front cover, press "option".
  • Answer Yes (by pressing 1) to the question in the display.
  • Your drum counter is now reseted. Press "option" again.
  • This time, press *, 0, 0.
  • Your toner counter is now reseted too.
(If nothing happens when pressing option, try using the back/clear button instead.)
Posted on Jun 15, 2009
Black Toner Cartridge Not Recognized.?
Check the contacts on the toner cartridge and in the printer are clean and shiny. They also must have no dent.
We on Fixya only try to answer questions via this page. We don't send mail.
Mar 13, 2015 | Toshiba E-Studio 356 Multifunction Copier
MY TOSHIBA E-STUDIO 452 HAS A MESSAGE OF INSTALL NEW TONER AND I HAVE INSTALL A NEW TONER ALREADY
Step 1:- Switch off the machine
Step 2:- Press 0 & 5 simultaneously
Step 3:- Switch on machine.
Step 4:- The display shows test mode.
Step 5:- enter code 200
Step 6:- the machine starts automatic adjustement of auto toner sensor , and when the display shows adjust mode then press enter on the display.
Step 7:- Now switch off & on and check the problem should be
resolved. If problem continues then maybe, changing your
developer may solve the issue.
May 18, 2012 | Toshiba E-Studio 3511 Color Copier
Toshiba e-studio 211 copier .Toner sign not remove please halp me [email protected]
Machine shows "Toner not Recognized" when correct toner is inserted into MFP.
It can be due to main PCB faulty.
May 28, 2011 | Toshiba Office Equipment & Supplies
Hi, My Toshiba E-Studio 3511 color copier has a error message of 'dispose of used toner.' Even if I followed the direction, the error message is still there and the copier can't work. Would you help me...
I am assuming you have emptied the old waste toner "box" and not replaced it with a new box. This is not a problem, just clarifying. If this is the case then you have toner packed into the sensor block which is telling the machine that the waste toner box is still full. Just look behind the waste toner box and look for a little set of wires. They lead to a small black sensor. Now look at the waste toner box where it mates up with the sensor. You will see a small square box area on the waste toner bottle. The sensor looks thru this block and if it is blocked with toner it will tell the machine the box is full. Just tap on the little block and make sure there is no toner in it and re-install the waste toner box and the indicator should go away.
Good Luck and Thank You for using Fixya.
Aug 11, 2010 | Toshiba E-Studio 3511 Color Copier
Dear sir, my toshiba e studio machine some time showing "dispose used toner" . I thing that means tonner is finished. there have 4+1 toner which we need to replaces Idon,t know. Please help me
Dear,
your copier e-studio 350 some time showing '' dispose used toner'' It dont mean you install new toner... its mean you dispose used toner box.. Dear open the copier frant cover
and dispose used toner white box...
Thanks
Best Regards,
Aug 05, 2010 | Toshiba e-Studio 350 Copier
Keeps on coming up with install new toner
The toner detection sensor in the toner hopper is either fouled or defective. This is why that no matter what you've done thusfar, it's still saying it needs new toner. Not an easy repair. Recommend a certified Toshiba tech to do the work.
Aug 28, 2009 | Toshiba e-Studio 232 Black and White...
Sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
Jul 20, 2009 | Toshiba e-Studio163 Copier
Toshiba e-Studio 25 and Windows XP
your computer connect to Copier thourgh USB cable port or parellal port .select first communication port.and install software.
Jul 24, 2008 | Toshiba e-Studio 232 Black and White...
Docucolor 12 error 9-356
That is a yellow toner empty message
Jun 09, 2008 | Xerox DocuColor 12 Printer
2050 Add Toner signal
Try resetting the machine
May 21, 2007 | Toshiba 2060 Copier
Open Questions:
Top Toshiba Office Equipment & Supplies Experts
Timothy Van Der...
Muntejaya Ginting
Muntejaya Ginting
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
