LG 47LG50 47 in. LCD HDTV Logo
D
David Lukasik Posted on Mar 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote not working nor do side buttons respond.
TV seems stuck on HDMI2 mode. It cannot be switched, the remote will not respond, nor can I get the Xfinity remote to accept any of the LG codes. I cannot adjust volume manually of via the remote. Changed remote batteries. Can watch TV via the Xfinity box, but none of the TV functions work.
  • David Lukasik
    David Lukasik Mar 29, 2016
    Thanks for the great/quick response!!
Level 3:
Top Expert:
  • LG Master 76,851 Answers
  • Posted on Mar 28, 2016
LG Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14991275
Points
237762
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Stuck on usb mode, ECCO 32' tv
Please remove all unnecessary attachment from your tv and then attempt to use your remote again. If the remote does not work properly, then you can move on to running a power cycle (ie unplug the tv for 30 seconds before plugging the power back in).
Then you can test the remote again. Otherwise, the tv might need a factory reset in order to overcome the issue at hand.'
Thank you.
My Bruhm 32 curve tv is stuck in usb mode, and i dont have remote
If your Bruhm 32-inch curved TV is stuck in USB mode and you don't have a remote, there are a few different things you can try:
  1. Try using the buttons on the TV itself: Some TVs have buttons on the side or bottom of the screen that can be used to navigate menus and settings. Look for buttons labeled "menu," "input," or "source" and see if you can use them to switch to a different input or exit USB mode.
  2. Unplug the TV: Unplug the TV from the wall outlet for a few minutes, then plug it back in and turn it on. This can sometimes reset the TV and clear any issues with the USB mode.
  3. Obtain a replacement remote: If you don't have a remote, you may need to purchase a replacement. Check with the manufacturer or a retailer that sells Bruhm TVs to find a compatible remote.
  4. Use a universal remote: If you have a universal remote, you may be able to program it to work with your Bruhm TV. Consult the manual for your universal remote or contact the manufacturer for assistance in programming the remote.
If none of these steps work, you may need to contact Bruhm customer support for further assistance.
Vizio TV. Can't get out of PHOTO mode. I have no remote. Side MENU button doesn't respond when in PHOTO mode. Need to Hard Reset... How can I?
^_^ Those answers are only for new remote but that's not the only way, There trying to ask in another way with out a remote.
None of Tv controls on side of tv will not work and remote will not work
MAY HAVE A STUCK BUTTON SUGGEST PRESSING EACH BUTTON HARD AND SEE IF ANYTHING CHANGES. THE MAIN MICRO PROCESSOR IN THE TV WILL RESPOND TO BUTTON COMMANDS BEFORE ALL ELSE SO IF THERE IS A STUCK BUTTON NO OTHER BUTTONS WILL WORK AND IT WILL NOT RESPOND TO THE REMOTE.
Can't change from HDMI2 back to HDMI1
You need to change via tv selections option for tv, this should be possible by selecting the source for tv feed. This should give various options to select hdmi11, hdmi12, scart1 ect. If remote not working to change look on the tv itself for the control buttons, normally on the back to 1 side (rh from front) then pressing the correct button. If this does not work try turning power off to tv for a couple of minutes and then turning back on. Hope this helps.
1helpful
2answers
Remote contol will not work
http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380052#h:1020.989
directv remotes are not guaranteed to work w/ all types of TV's. when programming remote to TV, make sure you are holding down MUTE and SELECT both at the same time for about 4-5 seconds. until it blinks twice at the top of the remote. also the slide switch must be under the "tv" mode on the right hand side. the website i provided is by directv, and has a list of their codes for the brand of tv that you have.
if you are trying to program a remote to a directv box, and none of the codes are working for the directv box, contact directv to have them send you a new remote.
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
