Question about Garmin nuvi GPS
I bought this at a auction it was in a box of goods and I don't have a pin # what can I do to reset it
Posted by Al Burke on
Jonathon summesfield
    Sergeant:
    Champion:
  • 285 Answers
To reset device, power off. Then power on but keep your thumb on the bottom right or top right of the screen ( Depending on model ) as it is booting up, then if done correctly there should be a message saying along the lines of " Factory reset item, all data will be erased " In theory this should reset the device to factory and remove pin.
Posted on Mar 27, 2016
I bought a notebook model Hp mini 1104 at a storage auction . I don't have the pass word to open it up. Can I bypass it some how ?
To bypass or reset the Windows password on HP mini, you need to download and install a Windows password recovery tool. Windows Password Unlocker can help you reset forgotten Windows local administrator, domain administrator and other user account passwords on Windows 8/7/Vista/XP/2008/ 2003/2000. No damage to computer data and settings.
1helpful
2answers
Cant log in to computer.dont know password. bought at auction
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode. XP only.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
  • Free software option would be Hirens Boot CD. This one is command prompt only. http://www.hirensbootcd.org/ Must follow instruction exactly.
Need to restore Casio te-4000f to factory settings. Advice?
The instruction manual is here. There is a way to reset the reporting data, if that is what you want. I don't see a way to reset all settings back to factory defaults, though.
3helpful
2answers
I forgot my pin number and master key please help
In the System Settings Menu, go to the 3rd page, then select "PARENTAL CONTROLS."
  • Select "YES," to change the parental controls.
  • You will be prompted for your 4-digit PIN.
    If you know the PIN, select the empty text box and enter the PIN using the on-screen keyboard, then select "OK" to continue.
    If you don't know the PIN, select "I forgot," then select the empty text box for the answer to the secret question and enter it using the on-screen keyboard. Select "OK" to continue.
    If you don't know either the PIN or the secret question, the Parental Controls will need to be reset.
    An Enquiry Number will be displayed. Ring the number given in the Nintendo DSi Operations Manual and provide the Enquiry Number. You will then be issued with a Master Key. Tap "OK" and enter the Master Key. Tap "OK".
  • Select "PIN" to change the PIN or "CHANGE SETTINGS" to update the setting you wish to change. Once the changes are made, select "DONE" to confirm any changes.
"If you don't know either the PIN or the secret question, the Parental Controls will need to be reset. Please call 1-800-255-3700 for assistance."
My son can't remember the pin numbers for his Dsi. How can we reset them?
Hello there,
According to Nintendo's FAQ for the DSi:
  • If you don't know the PIN, select "I forgot," then select the empty text box for the answer to the secret question and enter it using the on-screen keyboard. Select "OK" to continue.
  • If you don't know either the PIN or the secret question, the Parental Controls will need to be reset. Please call 1-800-255-3700 for assistance.
  • Hope this helped!
    Can i bypass the coin operation on my washer and dyer that i bought at a auction it came with no key
    There's a reset button next to the coin box can adjust the $ to 0. Like resetting a clock
    1helpful
    Lost Pin for Garmin Nuvi 360
    Unfortunately without the receipt you won't be able to make this work. When a Garmin PIN is set the user is allowed to pick a location that they can go to in case they forget the PIN. If they turn the unit on while at that location the unit will not ask for the PIN. The only other way to reset the PIN is to sent it back to Garmin. If it was bought at a police auction they would have supplied you with some kind of a transaction record. I would call Garmin Support at 800-800-1020 M-T 8AM-6PM Fri 8AM-5PM Central time. Explain the situation to them and they might be willing to fix it for you. Normally if they are sent a GPS that doesn't come with a receipt they will contact the Police in the registered user's area. Good luck.
    Pin number
    There are only three ways to unlock the GPS.
    1) Get the PIN from whoever you bought it from.
    2) Take the GPS to the location it was at when the PIN was set.
    3) Send the unit to Garmin to have it reset. For return information: CLICK HERE
    If you can't get the PIN from whoever sold it to you online, it is probably a stolen unit. You should contact your local police dept with a the serial number to see if it turns up in their database. If it is stolen, you may be eligible for a refund from the online auction house because you were defrauded. At the very least you should file a complaint with the auction house to prevent this sub-human from screwing other people the way he screwed you.
    GPS Logo
    Top Garmin GPS Experts
    Tom Chichester
    Steve P
    Steve P
    Aron
    Are you a Garmin GPS Expert? Answer questions, earn points and help others
