Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
1Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down. 2Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
It sounds like you have a faulty switch. The switch located behind the start button controls both the on/off setting and the buzzer. You can either replace this switch (which will likely take care of both problems) or you can take it apart and adjust the contacts. You can test them with a multimeter before and after to make sure you've got them adjusted properly.
If the model number you have this listed under is correct, there is a buzzer module located inside the control panel. It is a fixed module, which means it cannot be adjusted. So, if you wish to get rid of the noise, you will have to unplug it. All you should have to do is UNPLUG the dryer and remove the back of the control panel. Disconnect any leads from the buzzer module and wrap them each in electrical tape to keep them insulated.
If you go to appliancepartspros.com you can view what I am talking about. The buzzer is listed as item 12 under the "Backsplash, Blower and Motor Assembly" heading. When typing in your model number use "DBXR463ED0WW. The digit before the that two letters is a "zero", not the letter "O".
If you have questions, or if you have not provided the correct model number, pease post back with the correct information so that I maybe able to assist you better. I hope this helps you.
