Miele Premier-Plus Built-in Dishwasher Logo
Question about Miele Premier-Plus Built-in Dishwasher
Miele GS2220 Sci error message F84
I have lost my instruction booklet. can anyone tell me what this error message means? thanks
Posted by thebee on
  • borosb Jan 18, 2008
    The same error code has appeared on my G1220 today. The manual is not specific about this code (except it states that for code FXX call the service). It seems that no water comes into the washer - have cleaned the water flter but the valve might not work (?) - hard to access it to check. Any suggetsions?
  • Anonymous Mar 27, 2014
    error code F84 & F85 appearing?
Goiana
Call Miele they will send a copy of the instructions booklet, I did and I got one
Posted on Apr 23, 2008
1helpful
Hello, I have a Miele G5575SCVI. I have had a F84 error code 30-40 seconds into load. A service technician came and replaced the water intake valve (in picture) because he thought it could be faulty. Still...
You should phone Miele, that is disgraceful. Tell them you want a factory technician to visit. Whomever you got isn't a 'proper' technician, plus you have expended money for items you didn't need replacing. With my Miele washing machine, the engineer attached his laptop to it to diagnose faults.
The only thing I have found is making sure the salt cover is tight. These machines go through a self test procedure and if sometimes fails, it aborts the program.
F84 Error code Miele\015 As soon as I install the dishwaser I got Error F84\015 Answers : This problem arises because the water inside the washer cannot get out.\015\012
\015\012Firstly......Make sure the salt cover if screwed on tightly (if you have one).\015\012
\015\012Then remove the filter(s) from bottom of the washer and clean.\015\012
\015\012Remove the drain pump cover and remove the one way valve (a ball bearing in a housing) and clean. Take note of rubber cover direction before pulling it out to clean.\015\012
\015\012Make sure the impeller (visible after you remove drain pump cover) is clean and spins ok. It will have a little resistance as you spin with your finger.\015\012
\015\012Make sure all is cleaned properly and it will all work fine again after replacing it all back in
and here
http://www.appliancehelponline.com/miele.html
F84 Slide shutter positioning fault
F84 error on miele dishwascher miele g2530 sci
There is a slide valve in the machine that directs the water to the upper and lower arms. The valve can become plugged or the signal to it can become lost. The machine is not an easy one to repair and you can do more harm than good if you don't know what you are doing. To give you an idea, you have to remove the machine and turn it upside down to work on it.
3helpful
F84 error on miele dishwasher G2534SCI
Hi
On that model to save water and energy water is sent to bottom and middle spray arms alternately. This is done via a shutter in the circulation motor. F84 mean this shutter is jammed,Most likely with debris,But is possible motor is faulty
The motor will have to be removed be sure
1helpful
I have a MIELE with a " F84 " falt code please help Thanks Phil
Hi
2helpful
What meens the problem F84 for miele dishwaser?
Hi
Miele dishwasher stopped, F84 flashing please help. Maureen
In most cases this means the circ pump is faulty - suggest calling a Miele service rep
Miele Dishwasher G 2630 SCi fails to fill.
Debris is jammed in the valve for water ejection. It's jammed slightly open. This happened to me and it was a very small piece of plastic from the lip of a tupperware bowl.
F 13 problem indicated on miele g2420 optima dishwasher
Its on the end of the water intake line - ussually under the sink - connected to the hot water line.
25helpful
4answers
Make sure all is cleaned properly and it will all work fine again after replacing it all back in.
Top Miele Dishwashers Experts
David Shaub
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
