You do not put water or oil in an air frier As the name suggests it uses hot air to cook food, If you cook home made fries then I suggest you boil the fries for a few minutes (depending on thickness ) then pat dry and put a light spray coating of oil on prior to Air frying.
Bed Bath & BeyondHome > Gifts by Interest > Healthy Living > Big Boss™ Oil-Less Fryer. "Big Boss™Oil-Less ... Right size for family cooking, fried taste without oil, does what it is supposed to do ! ... I purchased a new one when my old Big Boss stopped working.
Feb 22, 2012 - The working of Big Boss Oil-Less Fryer is very simple. ..... I am returning it because it does not work (does not turn on) but I don't want another ...
Oil wears out and gets contaminated. If you overload the fryer the temperature will drop and your food will adsorb it and contaminate it. Watch the temperature when you load it, I had a limit of 10F drop. Pre-cooking your frozen items will help a lot. I would replace the oil on a weekly basis depending on your volume. Empty the fryer, clean it and filter the oil every day. This will help a lot.
check your hot oil level, it may be above the mark. also follow the maximum recommended batch loading. overloading fryers will result in oil spillage (overflow from tank) during cooking cycle.
350- 400 will do fine, but remember to not have much ice on them when you place them in the hot oil as water and hot oil do NOT like each other and the oil will come up and out of the fryer...
Oil darkens with use the oil food molecules burn when subjected to high prolonged heat.
When frying foods such as fish or chicken use the oil once.
Do not filter oil over to reuse. Storing the oil in the refrigerator
may extend the life of the oil, this should not be done ever. This
process of chilling the oil and then burning the oil to room
temperature causes excessive splattering furing the heat up.
Storing the covered oil in a cool dark place, for up to three
months. ( remember to check oil when you use for color, smell, or
excessive foaming. Throw out if there is signs of all the above.
This unit has a warranty for one year from the day of purchase.
Cooking:
When starting let unit reheat 7-10 minutes. This will get the heat
to desired temperature. Re4ady light will cycle on/off during frying as
temperature fluctuates due to food load.
Types of foods cooking: temperatures and time of cooking
Chicken strips 375 F. 5-8 minutes
Chicken pieces, bone-in 375 F. 15-20 minutes
Fish, battered 340 F. 8-10 minutes
French fries, frozen 375F. 3-5 minutes
F375F. 3-5 minutes
Onion rings 375 F. 3-5 minutes
Shrimp, breaded 375 F. 2-5 minutes
When frying frozen food if iced rub off lose as this can make the
temperature of oil cool down. Pre-cooked frozen food cooks faster and
does not come out oily.
I cannot wait to start cooking in mine as I got it for a christmas gift. Great recipes in the owners manual:
Apples fritters yum yum,beer batter for fish or chicken, deep fried
chicken , chicken Kiev, quick doughnut made from biscuits, add topping
of ground cinnamon and suger.
I just got one of these w/Instructions, Says fill oil to fill level line inside. Cooking oil or shortening. Never use more than (2) - 8 ounces cups of cooking oil or (1) pound of shortening. Hope this helps!
Some Deep Fryers heat up faster than others, please see details below for pre-heating times:
Non-Immersion Element (No element in the Oil): 25 to 30 Minutes
Immersion Element (Element in the Oil): 7 to 10 Minutes
Are you by any chance overloading the fryer? try smaller batches.
Preheat the oven to 180 to 200 F.
Heat the oil in the fryer to 280 or 290 F. In small batches appropriate to the size of the fryer (fries for a serving of 4 people may need to be divided into 2 or 3 groups), fry each batch for about 8 minutes at this temp. Remove to a holding bowl. They will look limp, nasty and oily. (This uses 1/4" square fries from baking pototoes cut with a standard mandoline.)
When all the fries have been precooked, increase the oil temp to 375 F. Add the fries back to the oil in the same sized batches as before. It will take 3 to 5 minutes for them to crisp and brown. Drain, salt, and move to a cloth-lined bowl and hold in the 180 F. oven. Let the oil temp recover to 375 F. and cook the next batch in the same manner. Repeat, holding interim fries in the 180 oven, until all the fries are done.
When all batches are done, toss to distribute salt and the new fries with old, and serve immediately. Properly done, all commercial french fries pale in comparison to these.
However, I cannot guarantee that this method works with frozen commercial products. I always use fresh baking pototoes. That said, the frozen product should work to its optimal advantage when done in small batches with the first batches held in the warming oven as the other batches are done.
If it still doesn't reach 300 F then by all means take it back to the shop and ask for a replacement. If you're out of warranty get an estimate for a repair.
Good luck and bon apetite ;]
