Question about AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA
I have a large crack in the top of the casing above the freezer element, and the casing has blown which is not allowing the freezer to get to full operating temperature
Posted by Noel Douglas-Wallis on
Nater13
    Master:
  • AEG Master
  • 610 Answers
What is a freezer element? do tell
Posted on Jul 12, 2016
Proline fridge
Do not tighten down the hinges on the top of the unit, until it is just where you want it. They have a very large range of movement to allow for the potential of a refer box becoming out of square.
When you got what you like, then crunch down on the screws on the top of the unit.
kindly,
Jim
Jan 13, 2014 | Freezers
Fridgidaire freezer warming up
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Sep 09, 2013 | Freezers
Our chest freezer isn't keeping food on top frozen although the bottom is still frozen solid?
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this help in solving the problem....
Jan 11, 2011 | Freezers
Coil in top of freezer and top shelf in freezer have very large buildup of ice, melted it out but it soon froze back over
Good day,
I assume this is a conventional freezer, not a frost free model.
That condition is caused either by a loss of refrigerant or an internal restriction in the sealed system.
Both are, I'm afraid terminal, unless the machine is under 5 years of age, in which case it would be covered by factory warranty.
Sep 05, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
My freezer started getting a lot of frost and ice around the top close to the henges. Now I am getting a lot of ice in the bottom of this freezer. I can break up the ice and remove it and it will be back...
there are only 2 reasons this happens but one cause (defrost element not working) 1st we check the defrost timer is working if not replace it if it is working go on to the last fault it can be - depending on the freezer it will have 1 or 2 defrost elements when one blows the ice will slowly build up if they both blow then the ice will build up within days unless you know your way around a multimeter it will be very hard to determin witch unit has blown in 70% of cases its the element but a service tech can tell you in a matter of minutes to save you time and money i would get a quote to get a tech in but now you know what to look for
best of luck to you
please remember to rate this repair .thank you
Aug 03, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Large gash in liner of freezer
If the liner is cracked you can place duck tape over the hole(it is available in white)to hide it. Be sure you are not covering any vents for air flow in the freezer.
If this is helpful please leave Feedback. Thanks, SnugglePants
Oct 19, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
The top of the freezer is not freezing.
Normal 0 If the bottom of the freezer is freezing (but only just), but the top is just above freezing, then your problem may be either your defrost timer or the defrost heating element. You'll need a thermometer to determine how cold (or not cold) your freezer is getting. Usually a freezer is happiest when it's full, so being too full is likely NOT the problem (there is room for air to circulate, right?).
If you're handy, you can troubleshoot the problem yourself by following the suggestions found here, as that may at least identify the problem. Replacing components inside your refrigerator isn't incredibly complicated, but if you're uncomfortable with taking things apart, you may be better off seeking the help of a properly trained professional.
Hope this information helps!
Aug 24, 2009 | Freezers
Freezer doesnt freeze and red light at top came on
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
thumbs up
Aug 17, 2009 | Freezers
Freezer is on and just stopped working
Aug 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
DOES NOT MAKE ICE
Aug 13, 2009 | Freezers
AEG 10.35 cu. ft. / 293 liter Upright Freezer Arctis A75320GA Logo
221 people viewed this question
Top AEG Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an AEG Freezer Expert? Answer questions, earn points and help others
