Question about Emerson Heating & Cooling
Need wire diagram
I Emerson Electric blower in a furnace Indian having problems with the wire diagram
Posted by dustin hamilton on
5 Related Answers
Anonymous
  • 448 Answers
SOURCE: need wiring diagram
If you're not a licensed HVAC tech......no you don't
Posted on Feb 21, 2009
farfield
Farley Redfield
  • 462 Answers
SOURCE: need wire diagram for GE electric furnace
Usually the older GE's are straight forward and any generic wire diagram will help you out. If its newer and a Trane made unit try A Trane dealer.
Posted on Mar 28, 2009
Donni Steen
  • 687 Answers
SOURCE: Anyone have a wireing diagram for a nordyne E1EH-015HA
Intertherm does not offer a wiring diagram for the E1 series anymore. So I have included a link to the E2 series. They are very similar and you may find this service manual helpful for whatever problem you may be having.
http://www.nordyne.com/literature/359a.pdf
Posted on Apr 11, 2009
Anonymous
SOURCE: I need a wiring diagram
I need a wiring diagram for an intertherm/nordyne gas furnase !!!
Posted on May 26, 2009
traxman57
SOURCE: need wiring diagram ,colman central
I have the diagram pasted to the cover over the sequencer. I only have a 5 megapixel camera, but I am willing to try and get a picture of it if it will help.
Posted on Jan 01, 2011
My ducane furnance blower wont ignite the thermost t keep going off
The blower requires proper voltage, I will include a diagram however if not familiar with power I advise against trying any repairs.
Mar 04, 2014 | Emerson Lennox Ducane Armstrong Furnace...
I have an Emerson (4 Speed) direct drive blower for my gas furnace. What is the process (wire color codes) to change speeds on the blower. (I have a red, black and yellow wires taped off in the wire...
There should be a wiring diagram on the motor itself. The colors of the wires vary depending on voltage and model. Generally you have a med/low and med/high setting, I'm not sure what you are getting to with the low/high setting unless you are trying to set up staging. Check the motor for a diagram, if that is not present post back with all of the wire colors coming from the motor and the voltage.
Sep 25, 2011 | Emerson Heating & Cooling
HELP!! New install of GMUH75-E3A - Main blower starts immediately on power up/ thermostat turn on. Burner never turns on/ignites. AC power is wired correctly and gas supply is connected. Switch is in the...
You need to find out if the problem is in the T-stat, T-stat wire or in the furnace you can do this in a few easy steps
Step 1- Unwire the low voltage from the furnace. Then turn the power back on and see if the blower comes on if it does then the problem is in the furnace and you will need to troubleshoot the furnace (see bottom of page for troubleshooting furnace) if it does not then proceed to step 2
Step 2- Wire the low voltage back up to the furnace (follow the wiring diagram below). And unwire the T-stat, make sure that no wires are touching each other, then turn the power back on to the furnace, if the blower starts then you have a short in the T-stat wire and you will need to pull a new wire. If it does not then proceed to step 3
Step 3- Turn the power back off at the furnace and wire the T-stat back up (follow the wiring diagram below). Turn the T-stat to auto heat 90 if the heat does not start but the blower just runs then you need to replace the T-stat.
http://www.hvac-for-beginners.com/furnace-troubleshooting.html
wiring diagram
Nov 24, 2010 | Comfort-Aire Heating & Cooling
Furnace blower motor dose not shut off.
Do you think it might be the relay switch
Feb 04, 2009 | Goodman GMS90703BXA Heater
Wiring NO, NC relay on Nordyne furnace
NORDYNE , GOODMAN, AND NUTONE ARE ALL BUILT BY SAME MFG SO IF YOU TRY ALL THESE MAYBE YOU CAN FIND THE HELP YOU NEED
Jan 12, 2009 | Electric Circuit Breaker Kit for Furnace
Heating & Cooling Logo
70 people viewed this question
Top Emerson Heating & Cooling Experts
jdthefixer
kmuss1
Level 1 Expert
Pete Norton
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
