It has a water supply. As soon as you press the start it sounds like the pump is running . Will not fill with water. Any help would be great. Cheers Glenn
This means the unit has taken on water to the base pan and will not allow you to do anything until the water is removed. Once the water is gone you will need to locate or fine why water reached the base pan to correct this problem. Most common reasons, too much subs, leaking hose, leaking drain hose behind the unit and traveled back into the unit. Without seeing the unit the cause would just be a guess. I hope this helps. If you unplug the unit allow 2-3 days to dry out, this may allow you to run the unit and locate the original cause of your leak. good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Hi Gere,
Just saw you comment after tinkering a bit.
I poured about 1 litre of water into it and it immediately pumped it out then filled and continued with the cycle normally.
I was starting to think it was the float switch.
I will go looking for a leak as soon as it cools down!
Also while it was operating there was a strange noise. It sounds like either something scraping, or the pump is sucking air. It is not continuous, only every now and then for about 1-2 seconds.
Strange!
Thanks
