Question about Motorola Radio Communications
I have this pair of Motorola TLKR T3, both in normal mode: I speak on 1 and hear on 2, I speak on 2 and I cannot hear on 1.
If I switch one of them to Monitor mode the one with noise, both work. The annoying thing is that on one of them you hear the noise. Also both of them work in Monitor mode. I have the original manual but I could not find any setting. I also saw some other posts which could not help me. I saw suggestions of some settings to be done but they were not clear on what steps to follow. I also saw suggestions on some filters to change but again no clear instructions.
Posted by Bogdan Dragos on
eradiostore
  • Motorola Master
  • 1,658 Answers
Check your batteries and clean your battery contacts with a pencil eraser. Transmit is the first thing to go when you have a low, bad or poorly connected battery. It would make a radio appear not to transmit to the other unit. Trade batteries between the units and see if the problem moves to the other radio, this would let you know if it is simply a battery problem.
Secondly, check your mic opening on radio two and make certain it is not covered or has debris in the hole.
You mention you have the manual, I will attach a link to the manual for others reading this post who may not have it.
When looking at the manual it appears using monitor mode checks for a weak signal. If this is the only way your radios will work together you could have one of the following problems:
1. Bad battery
2. Too far apart
3. Not on the same channel as one another
4. A radio with an internal problem
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwj3wY_N7ojMAhXiw4MKHcW4A8kQFggpMAI&url=https%3A%2F%2Fwww.motorolasolutions.com%2Fcontent%2Fdam%2Fmsi%2Fdocs%2Fbusiness%2Fproducts%2Ftwo-way_radios_-_unlicensed%2F_documents%2Ftlkr-t_series%2Fstatic_files%2Ft3_manual_eu.pdf&usg=AFQjCNG535lkOTh8xUvxv_zPdIjyT2unWw&cad=rja
Posted on Apr 12, 2016
4 Related Answers
Anonymous
SOURCE: One of my tlkr-t3 walkie talkie's will not recieve.
They worked fine the first time we tried them out. Then they were put away for several weeks, and when they've been switched on, one now doesn't send. I checked this by the other putting in scan mode but it doesn't stop scanning at the channel it is assumed to send with. I tried all the channels for sending but neither one is detected. The other way around, so the first one in scanning mode, the 2nd in send mode, works fine (the scanning stops at the channel of the sending one, as expected).
So my conclusion is, that one doesn't send.
I interchanged the (fresh) batteries, but this doesn;t change.
So what could be the problem?
Posted on Jul 30, 2010
Anonymous
  • 27 Answers
SOURCE: motorola tlkr t3 both units power up ok they are
Your PL or DPL is not set correctly.
Check your owners manual, you can set this with the user buttons on the radio.
Press and hold the PTT button while turning the radio on. this will put the radio in the programing mode.
Be careful, if you do not know how to set the PL DPL or frequency you could make the problem worse.
Posted on Aug 24, 2009
Anonymous
SOURCE: TLK3 T3 Motorola permanent static noise
Mij TLKR T3 has he same problem. This solution does not work for me.
Posted on Jul 23, 2010
traviskelly8
traviskelly8
  • 62 Answers
SOURCE: I have 2 Motorola TLKR-T3, I haven't used them for a few months but now I replaced the old batteries with new ones and one is not reciving but transmitting, and the other one is transmitting but not r
Try to google or contact maker for
reprograming codes or buttons to hold down
or a web site to download it from an hook them
to computer an load. Sounds like a program
prob
Posted on Jun 01, 2014
Philips 190G having issues using it only as speakers. Stand-alone Speakers mode
Your TVs sleep mode is activated. Disable it on your TVs menu under settings http://download.p4c.philips.com/files/1/190g6fb_00/190g6fb_00_dfu_aen.pdf also d/l new drivers for your monitor and install them.
Mar 09, 2015 | Philips Computers & Internet
Monitor has no signal
have you tried you PC with another Monitor?
I'm expecting that you still have same problem.
Is your PC making any audible noise, beep sounds?
May be you should have your PC checked
Mar 15, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
When switching on the monitor v7 it makes a eletrical arcing noise bottom right corner. has to be switch on/off around 12 times for the screen to light up regards Tony
sales669, You or a qualified electronics technician will need to open unit for inspection and repair. Do not use unit if you smell ozone and continue to hear noise!!!! Any one or a combination of things can be causing your symptom. Do you have any possibility of doing warranty service, or is unit to old? In fact if it were me, I would disconnect it and use a spare unit until v7 lcd is repaired. Read more of my fixya profile to see if something fits your BLACK SCREEN problem. I would guess that your power supply inside of monitor needs some work done! 12fixlouie
Feb 03, 2010 | Videoseven V7 L19PS 19" LCD Monitor
I have an Acer Aspire One MiniBook. I once had it hooked up to another VGA monitor. Now when I log in it shows the ACER logo and the XP screen then turns black. i can hear the windows start up sound and...
try pressing the fn key and F5 or look for 2 monitors on one of the F keys its F5 on my acer 5520 that switches display modes also try going into the bios i think its F2 as soon as you turn on the laptop press F2 or look on the screen for the key to enter setup or bios and restore everything to default save settings restart
Nov 06, 2009 | Acer Aspire One AOA150-1635 Notebook
Monitor stuck in power save mode
This might be problem with your with your monitor or videocard.
Click Here to Troubleshoot.
Thanks, PREM
Mar 31, 2009 | Dell Dimension E520 PC Desktop
Monitor Issues
press the Fn and F4 keys at a time just it will switch to single monitor then display will show
Mar 26, 2008 | Acer Aspire 3100-1405 Notebook
Plazma TV buzzing noise
I have the same problem I can hear buzzing over the volume of the tv into the 30 range. I've had a tech out 3 times and he's coming out for a fourth. He's changed to power supplies and is bringing the 3rd next visit. From what I've read it has either to do with power supplies or grounding strips.
Jan 18, 2008 | Televison & Video
ASRock K7S41 no boot screen at all
Try plugging the monitor to the onboard video card and then enable the graphic card in cmos settings.
Dec 10, 2006 | Asrock K7S41 Motherboard
Radio Communications Logo
330 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
