Epson WorkForce 435 All-in-One Printer - Color 5760 x 1440 dpi Logo
j
john clarke Posted on Mar 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can i find instructions for using an SD CARD
Level 3:
Top Expert:
  • Epson Master 76,851 Answers
  • Posted on Mar 25, 2016
Epson Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987291
Points
237762
You can see it everywhere. Just look around.
Error 50
The "E50" error code indicates formatting a SD card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem.
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Error 50
1helpful
Error 30
Error 50
Error 30
Error 50
Error 30
Error 50
2answers
Error 30
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
