SOURCE: Taking apart
Unless you are familiar with digital products, you really don't want to take your camera apart. I am curious as to what is wrong with the camera.
SOURCE: How do i take my emachines m6811 laptop apart for a cleaning?
Well the company that made emachines at that time (Trigem) went bust so no support from the makers....
Best thing to do is search google for a dismantle guide or dissasembly or somthing like that...
Sorry not the most helpful answer in the world...
Matt
SOURCE: how to take apart cadillac 2003 themostat
Go to your local public library and check out a service manuel for your car in it will be a step by step procedure on how to change your themostate, as well as a host of other important things specific to your car
SOURCE: how do you align the blade to the mitre slot on a
How did the blade get out of whack? Take the blade all the way up, put a straight edge against the blade, measure to the miter slot front and rear, if it is not the same, you will have to lightly loosen the carriage underneath and bump the thing over one way or the other with a lead hammer. Get it straight, then torque it back up. You should be all set. You can set your fence to the miter slots the same way. lock it down and check it, if it isn't right, adjust the fence, all fence adjust , from the cheapest to the best. Hope this helps.
SOURCE: How do I clean the dust off the sensor on my Canon
Sensor cleaning is done on DSLR cameras, not on point-and-shoot cameras. If you take it apart without the proper equipment, alignment tools, and not to mention knowledge, you will end up with a paper weight.
