Question about Video Cameras
Need a 2dv male entry on the camcorder or a il-44535/2dv/4dv cable.
Posted by Henk Hoitink on
Where do you get L4415/IL4435/2DV/4DV i.LINK cable
Try searching eBay for that cable. I just did, and people are selling them for about $2.
Jun 28, 2014 | Sony Handycam DCR-TRV25E Mini DV Digital...
I Have a Samsung handy & easy Hi 8 NTSC SCL901 camcorder and i want to know if there is a cord that i can buy to put what i recorded on my computer?
You need this cable or one that is labelled as USB to Mini USB.
http://www.amazon.co.uk/AmazonBasics--Male-Mini-B-Cable-Meters/dp/B001TH7GUK/ref=sr_1_1?ie=UTF8&qid=1307984144&sr=8-1
http://www.play.com/Electronics/Electronics/4-/5889160/USB-2-0-5-Pin-Mini-B-Cable-1-8-Metres/Product.html?searchtype=allproducts&searchsource=0&searchstring=mini+usb&urlrefer=search
Jun 13, 2011 | Samsung SCL901 Hi8mm Camcorder
Where can a get a replacement usb cable fro aiptek dv3100 pocket camcorder?
This camera uses a USB Type A Male to Type B Mini 4-pin Male cable, you could find it at any Electronics / Computer parts store, i.e. Radio Shack, Fry's, etc, bellow there's a picture of it as reference, good luck.
Feb 28, 2011 | Aiptek Pocket DV3100 Camcorder
I have an ASUS 1005 HA Seashell netbook,and i an
You need a DB15pin male VGA to DB15pin male VGA cable - you cannot use rgb with this netbook. This type of VGA cable is available on Amazon at a very good price and at many different lengths.
Mar 02, 2010 | ASUS Eee PC 1000HE Netbook
How to connect the dam thing to a computer and what driver do i need for the canon dw-100 burner to work on the f computer
You must have got a cable to connect it and use any Writing software like nero to burn discs
Oct 24, 2009 | Canon DW 100 DVD-RW Burner
Toshiba Satellite- A135-S4477 unable to connect firewire
There are generally three different types for firewire connectors. In the laptops its usually the mini contact(type 2) so is even on the camcorders. on the desktop PCs and MACs however it could be. either type 1 or the type 2. There is a thired type (B) which is less common.
The link shows all the types, male and female:
http://www.l-com.com/content/Article.aspx?Type=N&ID=95
Hope it helped
/BS
Feb 24, 2009 | Toshiba Satellite A135-S4527 Notebook
Firewire and playback on TV
I don't know it this will solve your problem but I'm using a 3 pole male plug and getting picture on the TV (but not great picture - see above).
Jan 01, 2009 | Canon ZR900 Mini DV Camcorder
Samsung SC-D363 won't load to my computer
If you are trying to move video that is stored on TAPE, you need to get a Firewire cable. Using the USB cable, you can only transfer photos and video that is stored on the Memory Stick Pro memory card (user-supplied). The Firewire cable has a standard IEEE-1394 male connector on the computer end and a mini IEEE-1394 male connector on the camera end. If you don't have a Firewire interface on your computer, you will need to get one. Good luck.
Nov 21, 2006 | Samsung SC-D363 Mini DV Digital Camcorder
Video Cameras Logo
48 people viewed this question
Top Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Al Rush
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
