You can restore your iPad through iTunes or iCloud to reset the passcode. Just follow below steps to make it.
If Find My iPhone app is on, you can try the socond method: Reset iPhone password with iCloud Find My iPhone. The detailed steps are shown as below.
Step 1. Go to icloud.com and log in with your Apple ID and password on your computer.
Step 2. Click Find My iPhone. Then click All Devices at the top of your browser window.
Step 3. Select your iPhone from all the devices listed. Click Erase iPhone to erase your iPhone along with its passcode.
Step 4. Use the Setup Assistant on your device to restore the most recent backup of your device.
After the restoration process is finished, your passcode will be erased and all your data will be restored from your iCloud backup. You will now be able to access your iPhone without any passcode.
For more methods, check: How to Reset Password on iPhone
Don't worry, if you prefer an easier way to do the job, see how you can achieve it and get your iPad unlocked on your PC or Mac on your own with the help of this website: automaticiphoneunlocker.com
If you repeatedly enter the wrong passcode, your iPad will be disabled for longer intervals before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect it to the computer with which you last synced it.
Note: You can configure your device to erase itself after ten consecutive incorrect password attempts. This setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock.
If you cannot remember the passcode, you will need to restore your device using the computer with which you last synced it. This allows you to reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced with the device, you will be able to unlock the device for use and remove the passcode, but your data will not be present.How to Unlock an iPad with a Passcode
1. Connect iPad to your computer.
2. Select iPad in the iTunes sidebar, then click the Summary tab.
3. Click "Check for Update." iTunes tells you if there's a newer version of the iPad software available.
4. Click Restore. Follow the onscreen instructions to complete the restore process. When restoring, it is recommended that you back up iPad when prompted. When the iPad software has been restored, you can choose to set up iPad as a new iPad, or restore your music, videos, app data, and other content from a backup.Please additionally note that Apple staff also cannot unlock an iPad for you without restoring the iPad, which will erase everything on it.
