Question about Ariston Technologies Ovens
What does code F53 relate to on my Ariston oven
Code F53 occasionally flashes an the fan runs for a few seconds, i have no manual for the oven. can you please inform me what the fault relates to.
Posted by frank bows on
5 Related Answers
bigg t
anthony james
  • 640 Answers
SOURCE: Whirlpool oven fault f03 shown
f03 error is a sensor error.you could have taken an ohm reading on the thermistor to see if it was bad.if you replaces the t-mistor then the only other component responsible is the board.make sure all the connections on the board are clean and tight before you replace it.
Posted on Sep 29, 2007
Anonymous
SOURCE: Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Posted on Nov 22, 2009
Bruce Hathcock
  • 3600 Answers
SOURCE: Ariston FM22 Oven No Control decals
Go to this site www.appliancepartspros.com and look up your model there and you can order the decals or replacement knobs there.
Posted on Nov 29, 2009
Anonymous
SOURCE: I have an Ariston oven (model;208587057) but no manual
Hi
Press and hold the two buttons with the casserole dish on (one is crossed out) and use + or - to change the time.
Hope that helps.
Posted on Feb 22, 2010
Anonymous
  • 4 Answers
SOURCE: i have just moved into a new flat and no manual
Try here:
http://www.manualsonline.com/ex/thread/view/idThread/3088468
Posted on Jun 09, 2010
F12 error flashing on the display
Keyword Ranking Analysis for ARISTON OVEN FAULT ...
www.webstatschecker.net/stats/keyword/ariston_oven_fault_code_f12
Keyword Ranking Analysis for ARISTON OVEN FAULT CODE F12 ... fixya.com.Ariston Technologies Ariston AWD120WH - "F12 error code" issues
Aug 18, 2015 | Ariston Technologies Ovens
Ariston wall oven error code f53 f03
I managed to resolve that problem. When you have BOTH F53 and F03 error codes, it's not a sensor fault (although F03 is the big cavity sensor and F53 is the top one)... it's a faulty capacitor trouble. On the main board there are 4 electrolytic capacitors, just replace all of them and you're ok again. It's quite simple and very cheap. :-)
Nov 26, 2013 | Ariston Technologies Ovens
Hi my Ariston oven shows in the display error 07. I have an ariston oven FZ 87.1 (IX)
problem je v nedostatku vzduchu pri ventilatori,treba viac priestoru pre ruru
problem is the lack of air when fan, need more space for tube
Jun 29, 2011 | Ariston Technologies Ariston FO98P...
Oven door wont open code f53 thermador how can i get it open food is in it
Hello,.
Welcome to FixYa.
The "F53" error code on your Thermador "C" series ovens indicates a upper door lock fault, makes sense since that is the issue you described.
Whether there is actually a fault with the lock remains to be seen. Here is what I`d suggest you try...
Locate the service panel for your oven ( should be an isolated 40amp breaker ) and turn it off for a few moments and turn it back on.
This will initiate the start-up sequence which activates and checks the controls and lock assembly, hopefully resetting it to the "open" position and subsequently eliminating the error code.
Let me know how that works or if you require further assistance.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Sep 29, 2010 | Thermador C302U Electric Double Oven
Jun 28, 2009 | Ariston Technologies Ovens
Kenmore Gas wall oven flashes F7 Code
Hi Indy2008,
You can find my solution to the most common cause of the F7 problem at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have helped over 1600 folks solve the F7 problem. The problem is usually with the touchpanel and not the ERC. My fix tells how to determine which part is faulty. Hopefully you will not need to purchase a new touchpanel, however, if you do, an internet search will lead you to lower cost sources.
Please let me know if my fix works for you. You can email me at:
[email protected]
Regards,
Powerman
Mar 19, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ovens Logo
131 people viewed this question
Top Ariston Technologies Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
