We dont have this engine here, USA.
but i have the WG jeep book,
starting page 12 , chapter 14
FUEL INJECTION PUMP BLEEDING
(1) If the fuel injection pump has been replaced,
air should be bled at the overflow valve before
attempting to start engine.
(a) Loosen the overflow valve (Fig. 18) at the
rear of the injection pump.
(b) Place a towel below the valve.
WARNING: WHEN CRANKING THE ENGINE TO
BLEED AIR FROM THE INJECTION PUMP, THE
ENGINE MAY START. PLACE THE TRANSMISSION
IN NEUTRAL OR PARK AND SET PARKING BRAKE
BEFORE ENGAGING THE STARTER MOTOR.
CAUTION: Do not engage the starter motor for
more than 30 seconds at a time. Allow 2 minutes
between cranking intervals.
(2) Crank the engine for 30 seconds at a time to
allow air trapped in the injection pump to vent out
the fuel injector drain tubes. Continue this procedure
until the engine starts. Observe the previous WARNING
and CAUTION.
(3) Tighten overflow valve.
HIGH-PRESSURE FUEL LINE BLEEDING
WARNING: THE INJECTION PUMP SUPPLIES HIGH-
-PRESSURE FUEL OF APPROXIMATELY 45,000 KPA
(6,526 PSI) TO EACH INDIVIDUAL INJECTOR
THROUGH THE HIGH-PRESSURE LINES. FUEL
UNDER THIS AMOUNT OF PRESSURE CAN PENETRATE
THE SKIN AND CAUSE PERSONAL INJURY.
WEAR SAFETY GOGGLES AND ADEQUATE PROTECTIVE
CLOTHING AND AVOID CONTACT WITH
FUEL SPRAY WHEN BLEEDING HIGH-PRESSURE
FUEL LINES.
WARNING: DO NOT BLEED AIR FROM THE FUEL
SYSTEM OF A HOT ENGINE. DO NOT ALLOW FUEL
TO SPRAY ONTO THE EXHAUST MANIFOLD WHEN
BLEEDING AIR FROM THE FUEL SYSTEM.
Bleed air from one injector at time.
(1) Loosen the high-pressure fuel line fitting at
the injector (Fig. 19).
(2) Crank the engine until all air has been bled
from the line. Do not operate the starter motor
for longer than 30 seconds. Wait 2 minutes
(3) Start the engine and bleed one injector at a
time until the engine runs smoothly.
end quote.
pump timing is on next page
or tank filter line priming before. above.
