Question about Zeiss Humphrey 740 Visual Field Analyzer
Why does it shut off from time to time while being used?
Posted by Tedd Koh on
My roper dryer works fine, it heats and the timer advances, it just wont shut off at the the end of a timed dry or auto dry. What do you think?
A timed drying cycle uses the timer alone to stop the drying cycle. Once it times out like an egg timer a set of contacts open up shutting off the dryer. Or a set of contacts closes to activate a relay which in turn shuts off the power.
Auto dry usually uses a moisture sensor which would do the same thing as the timer. Once it doesnt sense moisture in the load for a predetermined time it in turn triggers a relay which shuts the power off. Some auto dry cycles just use the timer alone and guess-timate the drying time by the selection.
If yours does not use a moisture sensor then most likely it is your timer/cycle switch. There may or may not be a relay involved.
Most dryers have a basic wiring diagram on the inside somewhere on one of the panels which will help.
Since yours is acting up on both cycles Im guessing you have a bad relay or connection to that relay somewhere IF it uses a moisture sensor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john_32f4b76dad4781c4
Dec 17, 2014 | Roper Dryers
Stand by timer shuts tv off after 30 sec sony tv
Sounds more like it's been set to do that. Use the following to shut off the timer mode. It's possible that the set is set to the wrong time of day but that is unlikely. You can shut off the timer mode using the on screen menu. Follow the instructions below.
Using the Timer Menu
Current Time Set your TV to the current day and time. Press to open the Current
Time menu:
1 Use the F or f buttons to enter the correct day and time, then press
2 Press to exit the menu.
Timer 1 and
Timer 2
Scheduled
viewing
Use the timers to program your TV to turn on and off by day, time,
duration, and channel. The timer duration is a maximum of six hours.
When the channel is fixed, it is not necessary to set the channel.
1 Use the F or f buttons to highlight Timer 1 or Timer 2, then press
2 Use the F or f buttons to enter the desired day, start time, duration,
and channel, then press . The timer status should be On when the
Timer has been set, and the timer light on the front panel of the TV
should be on.
3 Press to exit the menu.
? When you perform Auto Program, Timer 1 and Timer 2 settings will be cleared. Also, in the event of
any loss of power, Current Time, Timer 1, and Timer 2 settings will be cleared
Apr 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hp 6735s wont shut down
using the button to shut it down is not recomended, but if you do not have programs running that is loading/saving data, it should be ok, in some cases it could damage the computer, you should see if it is under worrenty and get it looked at or call tech support and see if they can help
Sep 28, 2009 | HP Compaq 6735s Notebook
I cannot shut down or restart my PC using the start menu prompts. The only way to shut her down is a hard shut down (manually turn her off).
There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
Try re-installing the non-responsive program and see if your computer can shut down normally again.
Aug 07, 2009 | Acer Computers & Internet
Sleep vs Shut down
It depends on how long computer is being used in a day.
for general use
you can shutdown your computer once in 2 days but i highly recommend not to put in sleep mode and betting putting in hibernate mode instead of sleep mode.
note: most of simple issues are resolved by restarting PC so you can guess now how important is to shut down computer.
Good luck,
Mar 25, 2009 | Apple 24" iMac Desktop
I m unable to shut down my inspiron..............
check if you can shut it down from the terminal window using shutdown now function.
Feb 26, 2009 | Dell Inspiron 710m Notebook
Cuisinart DCC-1000 shuts off on it's own
Unplug it for 20 minutes or longer to fully reset it. At that point, the default shut-off time will be two hours, unlss you use the auto-off to increase this time limit to 3 or 4 hours.
-Tha Mp3 Doctor
Dec 20, 2008 | Cuisinart DCC-1200 Coffee Maker
Over the range MV Oven shuts down from heat
it is triggering the overtemp switch. try to check the vent outlet, it could be clogged with dirt. or the cooling fan of the magnetron is no longer running. could be stuck up because of not being used for a long time.
Feb 20, 2008 | Microwave Ovens
Zeiss Humphrey 740 Visual Field Analyzer Logo
462 people viewed this question
Top Zeiss Science & Laboratory Experts
Gep Pep
 Brian Main
Brian Main
Terry
Terry
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
