Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Tv won't give a picture. There is power but no controls work
I did unplug for a few minutes that worked last night but this morning the same problem
Posted by Will Dixon on
4 Related Answers
Anonymous
SOURCE: Toshiba 20vl14 power loss
Mine does the same thing!!
Posted on Apr 26, 2008
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: i have a toshiba 37 wlt 58 lcd tv . i watched the
Sections of the power supply may have gone out, or it detects short circuits in the backlight inverter board or in the power supply itself.
Those are the two areas you need to check. Look fo bad caps with leaking/bulging top fist in the power supply.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Aug 13, 2010
gopakumarg43
  • 76633 Answers
SOURCE: TV picture won't come on, just get white static
Hello
There may have some crack or loose to the circuit board during drop. Just get it serviced. No more component should be repalced. Only service should be done. OK.
Posted on Feb 03, 2012
SD Tech
SD Tech
  • 14553 Answers
SOURCE: I have sound, but no picture. It just blinks, with a faded back ground
Try to unplug set and or a box if used from power for a while, plug both back and see if a reboot that will happen helps or not.
Posted on Dec 10, 2012
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
I have a 52"
Need model number and blink code at time of defect.
1helpful
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
2helpful
Touch pad is not working, says enter in time and none of the buttons work. I have unplugged it and then plugged it back in nothing changed. Worked last night at dinner, went to bed, didn't work to defrost...
Had a few of these happen on this brans and model. All had to have new touchpads fitted. If you are handy it is a matter of opening case and unplugging and replugging and tightening a few screws. Cost about $110 for new pad.
Please rate my help++++Thankis for using FIXYA
3helpful
2answers
F2 and F3 Errors just started on my GE Electric Range
I had to clean the contacts in the control panel to fix my same problem.
Worked fine lastnight but this morning when I tried to turn it on there was no picture, but there is sound
TRY UNPLUGGING IT FOR FIFTEEN MINUTES THEN REPLUG IT IN,KNOW IT SOUNDS STUPID BUT WORKS SOMETIMES
1helpful
RCA 32V420T 32" TV
reset by unplugging AC cord for few minutes, a few hours,or overnight,if needed.Let me know if that does not work.T.
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
Top Toshiba Televison & Video Experts
 Grubhead
Grubhead
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
