I forgot password and now I cant access my tablet.
I just wonder if there's a way to reset it externally? It's a Trio Pro 9 tablet with windows 8
Posted by Karla Dubois on
ajeeter4
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Here are some options which came from the trio tablet website: What do do if forgot my password to unlock to my tablet
Factory Data Reset - Factory Data Reset can be accessed through your Settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From Settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD Card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset Tablet and Erase Everything.
  1. Tap on Settings.
  2. Tap on Backup and Reset on the left hand column.
  3. Tap on Factory Data Reset on right hand side.
  4. Tap on Erase SD Card. (optional)
  5. Tap on Reset Tablet and Erase Everything.
Or
Hard Reset G2 - In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults. First you need to make sure your tablet is powered off. Hold down on the Volume + button and hold down the Power button at the same time. As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen. At this point you will see a screen with boot options. Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option. On the next screen use the Volume - button again to go down to Yes and use the Power button to select. At this point it will be going through the wiping and resetting process. When it's done you will see the first screen you came to when you first started the setup. Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset
  6. Tap Power button to select.
  7. Use Volume - button to scroll to Yes.
  8. Tap Power button to select.
  9. Tap Power button to select Reboot System Now.
This site also had some tips: Different Hard reset factory wipe methods for Android Tablet
Posted on Mar 23, 2016
1helpful
Asus tablet, Windows 8, forgot password and won't let me reset no matter how many incorrect passwords I put in.
the whole purpose of the PW is so others can't read your private data.
So why would guessing it ever be good.?
What screen fails. THE W8 WINDOWS login?
yes/no.?
yes, then do all users on that screen fail to login
is the login local or windows Live login.
live login is easy to reset at ms.com
MS page to do that is outlook.com (using 2nd PC that works)
next time write it down, say in book only you know using postitnote. (memorize only the page #)
end the drama forever.
I forgot the password to my android 9.7 how do I rest it?
Factory Data Reset- Factory Data Reset can be accessed through your settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset tablet and Erase everything.
    1.Settings
    2.Backup and reset on the left hand column
    3.Factory data reset on right hand side
    4.Erase SD card (optional)
    5.Reset tablet and erase everything
I have a asus notebook sonic master with windows8 forgot password for asus notebook sonic master with can I change or reset password to get in notebook with android USB
If it is windows 8 then you can change your windows live password by using another computer, tablet, or smartphone to access the windows live webpage. Then you will say forgot password. Follow the steps and it should guide you through resetting your password.
1helpful
3answers
I FORGOT MY COMPUTER PASSWORD, USING WINDOWS 8
On another machine, go to the link I post. That's the link to reset your Microsoft password. Microsoft has now lumped all of its services pretty much under the same umbrella, so resetting the live.com password will also work for your stuck computer. Sign in to your Microsoft account
14helpful
I forgot my password to my Coby Kyros mid8048 i was wondering how you could reset it please help me
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
7helpful
How do you reset a trio stealth pro tablet after being locked out?
I have a trio stealth pro tablet and I'm lock out how do I get back in
13helpful
2answers
Forgot password on Trio 4.3" Internet tablet
If this tablet is linked to a gmail account, then enter five incorrect passwords and you should get a Forgot Password button. Follow the prompts to reset it.
Alternately you can factory reset.
  • Power off tablet
  • Tab power button then press and hold power + vol down
  • You should get a menu. Choose the factory reset option
Ekse
 Grubhead
Grubhead
