SOURCE: sony amplifier power
Hi uscsae, This is usually caused by a blown fuse or a blown capacitor. The fuse would be cheap and easy to fix, the capacitor would be expensive and replacement would be my choice. If you are pretty handy with electronics, unplug it, take the cover off the unit, and look near the capacitor for the fuse. Check the fuse for a break in the wire inside it. You can get these fuses at Radio Shack. Hopefully this is what it is, and will be a cheap and easy fix for you. Let me know how it goes. Best regards, nightdiver
SOURCE: Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
SOURCE: Samson Servo 170 Amplifier
check see if youy have some coving the vent or the speak connect right
SOURCE: After 10 years of function
I would have the power supply capacitors replaced. After several years ( from heat and age) they dry out and dont put out proper DC voltages to run the amp.
SOURCE: i am trying to find schematics for the samson 120
Here is a direct page to your needed information http://www.samsontech.com/products/productpage.cfm?prodID=1821
