Question about Birds
Hens in cages - Birds
Posted by Sandi Zarch on
  • Brett Duxbury
    Brett Duxbury Mar 20, 2016
    Hi Sandi Zarch, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
How do I remove the cage on this fan to get to the blades
look carefully at the edge of the cage, there are several different mechanisms for holding the cage together. one could be a small screw on the very bottom of the cage this can be loosened and then the front of the cage can be pried off the rear of the cage taking care not to damage any of the clips. another mechanism is hinged clips which can be swung away from the cage, sometimes requiring the use of a needle nose pliers if very tight. Some of the old Patton fans have metal prongs and these can be gently pushed in while removing the front of the cage. Basically you look carefully and figure it out. Refer to the manual which one can usually search for online.
Oct 09, 2015 | Dryers
Tip
"Hack your PSP" guide
1.)Here are some termins i will use:
OFW-Original firmware,this is your system software
CFW-Custom Firmware,Modified firmware
HEN-Homebrew(home-made)enabler,this is much like a CFW without some features and its not permanent this means its gone after a hard reboot(taking out the battery or completly shutting down the system)
XMB-CrossMediaBar your PSP menus
PANDORA battery-a modified battery that allows you to put your PSP in service mode and do wathever you want with it its used for unbricking,downgrading and installing CFW.
BRICK-Its when you mess with your system software and damage it,its called flashing,its called a BRICK since your PSP becomes useless as a brick.
2.)PSP 1000 (FAT/PHAT)
This is wath it looks like:
ANY PSP 1000 is hackble
Ways of hacking:
1.You can use a Pandora Battery that you have to buy
*how to use a Pandora Battery:after you buy a Pandora and a MMS(Magic Memory Stick) insert them in your PSP and you shoud see a menu with CFW you have on your MMS.
2.)CFW or HENs depending on your firmware you can use CFW or HEN without pandora.
PSP 2000 with non V3 MOTHERBOARDS:SAME as PSP 1000
PSP 2000v3/3000/Go:
maxim615_2.jpg3000
maxim615_3.jpgGo
1.)On the 2000 and 03g 3000 you can have LightCFW or HEN
on 4g 3000 and GO you can have only HENs
CFWs:5.03 GEN,6.35 PRO-B,5.50 GEN
HENs:6.20 TN HEN
LINKS: http://www.psp-hacks.com/file/2052 6.35 PRO-B
http://www.psp-hacks.com/file/2046 6.20 TN-C
http://www.psp-hacks.com/2009/12/15/psp-custom-firmware-5-50-gen-d3-and-5-03-gen-c-for-hen-released/ 5.50 and 5.03 GEN
on Mar 01, 2011 | Video Game Consoles & Games
When it comes to bird cages, why is size so important?
Cage size is a very crucial element in regards to proper bird care. The tail of your bird should never touch the back or bottom of the cage when sitting on their perch. A very general rule to follow is that the width of the cage should be at least 1-1/2 times as wide as your bird's wingspan. Keep in mind that it is not just your bird(s) inhabiting the cage but you will need a perch and most likely some toys. My personal recommendation is to buy the largest cage you can afford.
Aug 29, 2012 | Birds
What's a single bird cage?
The single bird cage comes in a variety of sizes and is suitable for only one bird. Check bar spacing and the width of your bird's wing span to determine the best bird cage fit. Elevate this bird cage to sit at a human's chest level.
Aug 05, 2012 | Birds
What's a travel bird cage?
The travel bird cage is usually a smaller version of a normal bird cage. The travel bird cage does not need to be large, nor does it need to be as durable as your bird cage. Be sure that your bird can comfortably fit in this cage for a short amount of time so that it will not become stressed.
What's a playtop birdcage?
The playtop bird cage provides a space for your bird to exercise and explore its freedom outside of the bird cage, and usually includes bird cage feeders as well. A solid top on the playtop bird cage is excellent for collecting food and other bird messes while the bird is on top of the bird cage.
Does the size of my cage matters for my birds?
In general, the larger and the more active the bird, the larger the cage one should use. The amount of time the bird will spend in the cage each day is also a factor. A bird that is caged most of the time requires far more space than a bird caged only at night.
Cardridge jammed
Hello hens,
Try reinstalling the CARDRIDGE, by taking them out of teh printer & then reloading them as instructed.
Also clean the printer head.
Mar 24, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Panafax Uf-770
Rare as hens teeth. What is your question.
Aug 21, 2008 | Office Equipment & Supplies
Birds Logo
978 people viewed this question
Top Birds Experts
Kardoc
Tom Chichester
NOEL
NOEL
Are you a Bird Expert? Answer questions, earn points and help others
