Question about Audio Technica Audio Players & Recorders
Audio-Technica AT-LP120 turntable. I have crackling in the passive speaker, but when I reverse the speaker wire,ie, red in black & black in red, the crackle appears in the powered speaker.
Have replaced Headshell complete
  • Audio Technica Master
  • 5,699 Answers
If you have replaced the cartridge then it must be the cartridge pre-amp that is faulty. If there are any other functions on the device such as CD, then it will not effect them. Unless there is crackling on any other function then the pre-amp has a problem. The pre-amp itself is generally a single IC. You can find it by following the turntable connection back to the inside of the amp. The signals will pass through the IC before being passed to the main pre-amp.
Posted on Jul 28, 2016
Anonymous
SOURCE:
Anonymous
SOURCE: Headshell for Denon DP-45F Turntable
The PCL-30 does not look like a standard headshell. I doubt the above answer is correct.
Posted on Sep 06, 2008
Anonymous
  • 515 Answers
SOURCE: Sony PS-LX250H Turntable Problem
If Sony does not have it available, you won't be able to find one. You can go generic, but you have to worry about size and fit.
- OPTiC
Turntable Technician
www.1200s.com
Posted on Sep 08, 2008
Anonymous
  • 515 Answers
SOURCE: Phono Preamp buzz
Ditto. Double check the ground cable. If it is connected, then try a different set of RCA cables. Also check the connections on your headshell/cartridge. Make sure all 4 wires are properly secure.
- OPTiC
DJ PRO LAB
DJ PRO AUDIO
Posted on Oct 08, 2008
Anonymous
  • 17 Answers
SOURCE: Turntable Crackling
sounds to me like your fader has popped! lube contact spray will not solve the problem, it will only clear it up for a few passes if any! PCV faders have covers inside which stop any lube getting right on the contacts! but in my experience as a scratch dj for 11 years is that contact spray only make the problem worse over time! best shot from here is to replace the fader, or get a mixer with optical/contactless fader i suggest a mixer with the 'eternal' fader i.e. ecler 360/80hak. hope this helps
Posted on Feb 11, 2009
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: belt is off my audio-technica turntable at-pl50
WASH YOUR HANDS FIRST! Any oils on the drive belt may cause slippage.
This is from the manual:
A) Remove the record mat from the turntable platter
(Fig. 10a). Through an opening in the
turntable platter, visually inspect to see if the drive belt
is around the motor pulley (Fig. 10b).
B) If the drive belt is not around the motor pulley: Lift
and remove the turntable. Place a thumb into each of
the left and right openings on the turntable platter; and,
using the fingers to press down on the turntable housing’s
surface, pull the platter straight up (Fig. 10c).
Avoid pressing on the tone arm.
C) With the turntable platter bottom side up, place the
belt along the outside wall of the turntable platter's
drive rim, making certain that the belt is smooth and
flat all the way around (Fig. 10d).
D) Put the turntable back on the center spindle, make
certain it is fully seated, and align one of its openings
over the motor pulley position.
E) Through the opening, carefully hook the turntable
belt with a finger or with the original red ribbon (never
use a sharp object) and pull the belt over the motor
pulley (Fig. 10e). Make certain the belt is not twisted
between the pulley and the platter’s drive rim.
F) Put the record mat back on the platter.
G) While holding the tone arm in its rest position,
slowly turn the platter by hand clockwise at least 10
rotations to clear the mechanism’s automatic cycle.
Posted on Apr 24, 2009
When connecting AT-LP120 Audio technica turntable to Onkyo stereo receiver TX-8140 I get distorted sound - the turntable came with set cables installed to connect. How do I resolve this problem
hi,
instead of plugging your turntable into "phono in" on the amp just try a regular auxilary input like aux ,video, or cd. sounds like the turntable output isnt like the old ones and may be just a regular output.
Sep 29, 2018 | Onkyo Audio Players & Recorders
Where is the audio output hole on the Audio-Technica At LP-120 USB turntable, so I can connect to my stereo system?
After reviewing some of these unit being sold on e-bay, I found some pictures that show the cable coming out of the bottom of the unit. I then went to this site
The most detailed Audio Technica AT LP120 USB Review and according to them, the cable is hard wired. This means the cable is not removable. If your unit does not have the rca cables coming out of the bottom of the unit, it may have been cut off.
Jan 03, 2018 | The Audio Players & Recorders
Sound comes out the left speaker very crackled
1: Faulty cartridge.
2: Faulty connection.
3: Faulty Pre-amp - in turntable or in main amp.
Apr 25, 2013 | Audio Technica Audio Players & Recorders
No right side chanel sound
reverse the phono cables to see if the other side goes out if it does you could have a bad cable or the wire is off at the catridge.
Nov 22, 2012 | Audio Technica ATLP120USB Turntable
I just purchased the AT-LP120-USB - it's was a beast to get the thing balanced correctly, but now i hear some very obvious crackling sounds that weren't there before when the tone arm wasn't...
as long as you have balanced your tonearm correctly, maybe its simply just a problem with your vinyl? could just be dust in the grooves or could be static build up, try cleaning your vinyl with an antistatic cloth to see if the sound improves.
May 05, 2011 | Audio Technica AT-PL120 Turntable
I have an Audio-Technica turntable (AT-PL50). I recently moved and when I hooked my turntable back up, the sound is terrible. It sounds distorted, similar to the sound of blown-out speakers. But, I checked...
it sounds like your cartridge is shot and damaged.
this turntable has fixed cartridge and only the stylus can be changed.
check out this manual: http://www.audio-technica.com/cms/resource_library/literature/0fb01429606842cf/at_pl50_om.pdf
Jun 20, 2010 | Audio Technica AT-PL50 Turntable
Phono Preamp buzz
Don't forget to ground the ground cable from the turntable.
Sep 15, 2008 | Technics SL-1200MK2 Turntable
418 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
GFXTech
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
