The audio codec used in the camera is not installed on your computer. Check the Olympus website to find out what they're using - perhaps there's a download available.
You have two options. If you normally transfer your photos by connecting your camera to your computer, remove the memory card before making the connection. This will allow the computer to see the photos in the camera's internal memory.
If you normally transfer your photos by putting the memory card into a card reader, use the Backup command in the Settings-1 menu to transfer the photos from the camera's internal memory to the memory card, then transfer the photos from the card to the computer as normal. See page 48 of this manual: http://www.olympusamerica.com/files/oima_cckb/TG-610_TG-310_Instruction_Manual_EN.pdf
It's not the camera, it's the memory card. SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts. You may have a software write protection enabled.
Select your Olympus and click import. It should import both photos and videos.
You can also try and select the videos you want using the file download module Windows displays when a new device is plugged in. If that doesn't work, try
Start > Computer > Olympus Tough TG-310
Then open the folders until you find the videos you want. Select them and copy them to your desktop (or any other preferred location).
I have had video issues with my Olympus TOUGH (could not delete them from the camera) which turned out to be a formatting problem with the memory card.
There is very little that can be done, salt water will corrode metal on contact, all eletronic parts have been compromised, if the memory card is still intact save your pictures and remove it from the camera to transfer to new hardware. Replacing the camera unfortuneately is the only option.
