HUMMER H3 V8 2005 2010 WORKSHOP REPAIR SERVICE MANUAL
get your car fix right now
SOURCE: BRAKE SYSTEM FAILURE
well what could of happend they probably put the battery on backwards and blew out a fusible link.The links run thru the wires by the battery and behind the alternator check it out Good Luck keep me posted
SOURCE: abs fault traction fail service
please see my notes at http://www.fixya.com/cars/r6003525-abs_traction_control_lights
Testimonial: "Thanks a lot., the reason was broken wire from right front sensor, at the moment all system are workinng, best regards Dmitriy fm Arkhangelsk,Russia."
The IPC detects a loss of serial data communication with the EBCM.
With out a factory scan tool your not going to be able to do anything with This . Save yourself some money an aggravation , take this to the dealer if you don't know what a serial data communication network is ! An I'm sure there are codes stored in the EBCM !
Wit
