The manual does not tell me how to reset voice mail; after 4 rings, a caller used to go into voice mail; now the phone just keeps ringing until the caller hangs up
Voice Mail is not a function or feature of any telephone set,
nor does the GE 29581 phone have an Answering Machine
System that might be confused with Voice Mail.
VoiceMail is an option offered by some (not all) Telephone
Service Providers. Check with your Telephone Service
Provider to learn how to go about using theirs if it's available.
The original GE 29581 phone User's Manual is available at:
http://www.manualslib.com/download/59417/Ge-29581.html
SOURCE: Message Greeting
The KX-T7456 is a proprietary system phone. You have a Panasonic phone system and a voice mail, both separate items with their own part number. Your phone can work on several different systems and use different voice mail so your first step is to determine the part numbers from the system and voice mail. Then you will need a "programming" manual or possibly "administrator's manual" NOT a "user guide" for at least your voice mail and maybe for the system as well.
SOURCE: Will Not go to voice mail
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
SOURCE: INCOMING CALLS
Not sure it this is a solution for ALL your problems, but...
I had a similar issue: Phone rings, caller ID info displays then seems to hesitate, then displays only "INCOMING CALL."
The issue seemed to be caused by interference with other devices on the same line (in my case, an alarm system).
Tech support had me change a setting on my TRU9466 base unit (this is one of the PowerMax 5.8ghz models). This is how we did it step-by-step on the base unit:
MENU
GLOBAL SETUP
IN-USE LINE SETUP
select LINE 1
switch to TYPE B
This seems to have solved the Caller ID "interference" issue -- my Caller ID now displays as it should. The Tech Support person suggested trying that TYPE A/TYPE B setting on "OFF" if TYPE B didn't solve the problem, but thankfully, it did.
Now Cheryl, it sounds like your issue is more involved than this -- I didn't have any connection problems -- but perhaps they're related -- you might try my solution.
SOURCE: NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
4.200
5.speaker
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
2.0:cancel
3.exit
4.exit
should see the normal display then.
