Question about Dometic Refrigerators
Dometic rm 2652 won't cool. Not on electric or lp. Sometimes it cools freezer to 38. It gurgles when on and the lp lights but nothing happens help unit is 10 yrs old but never been used
Posted by Jennie Young on
David Spradling
    Top Expert:
  • Dometic Master
  • 11,389 Answers
Bad cooling unit replace or replace unit
Posted on May 25, 2016
5 Related Answers
Anonymous
  • 93 Answers
SOURCE: Dometic rm 2652 fridge works on a/c. i get a check
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Posted on Mar 15, 2009
Joe Hogan
  • 10865 Answers
SOURCE: I have a Dometic RM 2652, the freezer works fine.
Here is the trouble shooting manual for your Dometic.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
It will tell you what the possible problem is.
Posted on Jun 04, 2009
Anonymous
  • 9 Answers
SOURCE: dometic RM 2800
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
Anonymous
I just saw where they have a recall on this model Dometic Refrigerator RM 2652. If you go to the www.Dometic.com and find the recall info you can type your Model and Serial Number into the boxes and see if your model is one of the ones recalled. Don't know if this link will work but try it first and it will bring you straight to that box I am talking about on their website. Its http://67.238.126.140/recall.php, if not go to the one above and find the recall information. Hope this helps.
Posted on Sep 15, 2010
Anonymous
SOURCE: Dometic RM 2652 Doesn't Cool smells of amonia
There is a recall on this product. Go to www.Dometic.com and look for the recall info...or try this link http://67.238.126.140/recall.php put in your model and serial number to see if yours if a recall...I believe it is and I have found the problems you are talking about at this website http://www.gasrefrigeration.net/Why%20they%20fail.htm. which is exactly why they are recalling this model refrigerator. Hope the links help...if not go to the first link and look for the recall page and you will be able to see if it applies to your rv refrigerator. Hope this helps!!!
Dometic rm 2652 RB feg no cooling, checked all fuses, and lights work, but no cooling
check fusible links if ok unplug thermistor let run if cold replace if not possible bad control board or cooling unit see if chimney hot if hot bad cooling unit
Jul 18, 2018 | Dometic Refrigerators
Dometic rm 2652 refrigerator will not cool
if voltage to unit remove thermistor let run if ok replace thermistor if not see if chimney hot if not heater element if doesn't work on LP bad control board
Nov 18, 2013 | Dometic RM2652 Refrigerator
RM 2652 RV refrigerator runs on gas, not on AC. Power surge took out power converter and refrigerator power module. Replaced converter and power module. All display panel lights working. Cools great on...
just had same thing happen to mine. replace control board. starting working on gas. one the ac I then replaced the ac heating element and now working great on ac
Mar 21, 2011 | Dometic RM2652 Refrigerator
I have a Dometic RM 2652 LP gas/electric its hooked up to 120V but no gas. will it cool if so how long will it take to cool and how cold is it suppost to get it
Sep 12, 2010 | Dometic RM2652 Refrigerator
Dometic rm 2607 makes a gurgling sound when started in a/c or lpg . no cooling, in fact the inside of fridge heats up.help ? thanks
If your cooling unit is gurgling, then you have air in the system or a bad cooling unit. There is a process known as "burping" that should help repair this. It is a rather lengthy process and will require two people.
1. Access the rear of the refrigerator. Turn off the LP gas to the unit. Remove the LP Gas line and the 12Volt supply. Unplug the fridge.
2. Remove the screws in the rear at the bottom and then remove the screws from the inside.
3. Pull the fridge out and lay it down on it's right side for 8 hours.
4. Flip the fridge on it's top for 8 hours
5. Now the left side, then back to normal.
6. Reinstall the fridge and turn gas back on.
Hope this helps,
Jeff
Jul 08, 2009 | Dometic CS-200 Wine Cooler
Dometic rm 2652 fridge works on a/c. i get a check light on lp gas, i can light burner with flame, it stays lit
Feb 25, 2009 | Dometic RM2652 Refrigerator
Stop cooling
These are run on amonia so they dont freeze up as or in a compressor. You will first need to know that it is level. Then were you using LP or electric? You might want to verify that it is lighting and that the rear of the unit is getting hot. You can e mail me direct at hunter42558sbcglobal.net. I am willing to help you through this and I am a certified rv tech so I will know what to have you look for.
Jan 18, 2009 | Dometic NDR 1292 Refrigerator
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
324 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Paul G
Paul G
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
