Question about Sony KDS-60A2000 60" HDTV
Red power light flashed 5 times
Noticed that you can't hear the color wheel spin. TV clicks but does nothing for about 30 sec then clicks off. Checked voltage to ballast 389v dc. Customer had another power supply board, but still same thing.
Posted by Steve Nagele on
rostit
  • Sony Master
  • 737 Answers
There is no color wheel. This is an SXRD TV. If you have 389 at the ballast, then your ballast is bad. 5 flashes is a bad lamp driver. No TTL signal return to the mainboard. Put a new ballast in. Do not try and measure ballast output without good high voltage gear. The startup pulse is close to 20,000 volts.
Posted on Sep 30, 2016
5 Related Answers
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Sony KF-50WE610 flashing power/standbylight
Its small board with few connectors and easy to replace.
You can buy required part from Part Store. You may see image of ballast supply there.
Posted on Jan 18, 2009
Anonymous
SOURCE: KDS-50A200 NO power up, red light flashes 5 times.
It is the lamp ballast.
Posted on Jan 20, 2009
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: 5 red flashs on power/standby light on kdsr60xbr1 screen blank,
Thats the error for lamp driver error. Which means the Ballast is most likely defective. You can get the replacement ballast for your model at the following link which comes with installation instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/kdfe42a10-ballast-assembly/cName/sony-parts
Posted on May 23, 2009
ripleymojica
Mando Mojica
  • 643 Answers
SOURCE: sony kf-50we610 power led flashes red 5 times
Needs new lamp or the fan is out.
Posted on Jun 02, 2009
Chi Chu
  • 8457 Answers
SOURCE: T.V. doesnt turn on and red light keeps flashing at Power Section
Ur power board have dead capacitors,Know how to solders?Take the tv aparts check for capacitors puff up or burst open in the power board.Replaced those capacitors.Or tries Shopjimmy.com,Ebay.com buy a refurbih power board.
Posted on Jan 21, 2010
62hmx95, blinking light, powers on then off
Examine in order the lamp, the ballast, the fans.
Apr 29, 2012 | Toshiba 62HMX95 62" HDTV
My TV will not turn on. When I push the power button, I hear a click and what sounds like a hard drive spinning up and then slowing down. After spinning for about a minute, it turns off. In about a minute,...
No,Ur tv have a colors wheel,it dead.The spinning u hearing is the spinning of the colors wheel is rubbing against it base axis.Hire a tv tech for this job,replacing the colors wheel is hard,because require take out many machanical parts,before,u can even replacing the colors wheel itself.
Oct 03, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
The power swith will turn it on and off by itself. Won't stop
This tv have a colors wheel.U hear grinding noises? Picture flickers black&white.That the indication the colors wheel is dead,need a new colors.U have Lamp LED front Lit up or flashes?That mean the projection lamp life is over,require a new projection lamp.U hear alots of clicking sound?That mean the Ballast board is dead,this board help to ignite the projection lamp.
Jul 10, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
TV won't stay on
Hello Fonzell!
Regarding the tv turning, my question is, do you hear a clicking sound? if so, it's most probable tio be your ballast, that might not have enough voltage to keep on with your lamp, and that's why it shuts off.
You could try replacing it and seeing if it resolves your issue, I believe they're running around 70 dlls..
have a great one ! :)
Apr 21, 2009 | Samsung DLP HL-P5663W 56" TV
Panasonic PT-53TWD63, TV will not turn on, Red power light blinks
It is most deffinately a convergence chip issue. The die for no reason. They can be bought online for around $10 dollars and anyone with experience with soldering can replace them pretty easily. I have done it.
Feb 03, 2009 | Panasonic PT-53TWD63 53" Rear Projection...
Lg ru52sz51d will not turn on intermittantly
Check fan if bad set will not turn on ,it will try to come on.Bad Fan.
Nov 12, 2008 | LG RU-52SZ51D 52" Rear Projection...
I need help with my DLP TV
If you have verified the votages are there at the color wheel and its not spinning the color wheel is most likely defective. the sound you hear when spinning by hand is most likely the bearing but that shouldnt stop it from spinning. but as i said if the supply voltage is present but it still wont spin. the color wheel must be defective.
Jun 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Power on, front panel lights on - no picture or sound
there are three commom problems with this set one is light engine color wheel or power supply to get any of those is hard they are in back order but on some cases if the power is bad this could be fix bad caps on it if you want to get deep on it e-mail me [email protected]
Apr 01, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Sony KDS-60A2000 60" HDTV Logo
77 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
