SOURCE: Toshiba e-studio 150, Problem H4
This is a fuser related error - the fuser is not warming up within a specified time frame. It could be the heater lamp or a thermostat/thermistor that is not working, possibly a bad fan. You can cancel the error code (hopefully the error does not come back) by going into sim mode. press the following keys one after the other "clear" "density select key" "clear" "density select key" then enter 14 and the copy start key. then restart the copier. If error code persists you could remove the fuser unit and look for any foreign matter inside the fuser. dirty thermistor or thermostat can cause this too.
Hope this helps
SOURCE: L1 subcode 00
L1-00 indicates feeding is not completed
within the specified time after starting feeding.
(The scan head locking switch is locked)
The white area and the black marking on the shading plate are used to obtain the difference in the CCD level values for judgment of lock. When the difference in the levels of which and black is small, it is judged that the black mark could not be scanned by lock and the trouble code “L1” is displayed.
SOURCE: Error code H4-00 and machine is "locked-up" in scan mode
go into service mode 05 400 set to "0" switch copier off than on
SOURCE: toshiba e-studio120, H4 error code. what it`s meen??
seems like heat roller problem.
enter code C, exposer light buttom, C and exposer light buttom , then all the indicator in the machine goes off. then enter 14 and press print buttom. Now your machine must work. If not Pls refer to technician.
