Broderbund PrintMaster® Platinum 17 Full Version for PC Logo
L
Lisa Lowe Posted on Mar 17, 2016
Error code 20 when saving as pdf - Broderbund PrintMaster® Platinum 17 Full Version for PC
2answers
How do I fix Printer not activated error code 20?
The "Printer not activated Error code -20" typically is generated when the PDF Converter encounters an issue with the activation code used to enable the printer. The PDF Converter might not be able to read the activation code (activation code registry entry was not found).
What does this error mean in the Class 9 Espresso EB5 USB coffee machin
Hello, Abdallh -
If you have the owner's manual for the machine, starting on Page 35 see the list of error codes and what they mean.
If you do not have the owner's manual, this is the link for it (PDF format, you will need Adobe Reader, which is free to open, download, and save the manual to your computer):
https://www.ranciliogroupna.com/filebin/images/Downloadables/User_Manuals/MAN_Classe9rev_AC_2.pdf
Note: There is no EB5 error code listed. Perhaps you mean error code E05, or error code E15.
Cant email or print invoices error code -20
which versions you use
QuickBooks 2011 versions only
  1. Download and run the QuickBooks Print and PDF Repair Tool.
  2. Once the tool completes, try the .pdf file-related task that originally generated the error.
  3. If the error still occurs, please try rebooting your computer and then try again.
http://support.quickbooks.intuit.com/support/Articles/SLN40733
for more help step by step visit
QuickBooks Online Support
2answers
Quickbooks pdf converter activation error 20
if you want to solved Quickbooks pdf converter activation error visit our site to help step by step QuickBooks Online Support
1helpful
I cannot save a calendar as a pdf file. I get the
When your want to save your file as .pdf extension, you have to select a "virtual printer" from your "Printers & Faxes" when you install the software you are using to save as pdf file.
If you select your physical printer install on your PC, the error message you mention will appear.
Hope it helps.
Windows XP Error: category 102 event id 1003
look like a system crash.
try to go into save mode and do a scandisk
if not, remove any newly install hardware or software.
restart the laptop.
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
