Question about Panasonic TH-42PV8H 42 inch MultiSystem Plasma TV
TH 42PV8H A MY TV POWER NOT ON RED LED 2 TIME BLINKS
PANASONIC PLASMA MODEL NO TH 42 PV8H A POWER NOT ON RED LED 2TIME BLINKS
    Top Expert:
  • Panasonic Master
  • 76,416 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Posted on Mar 17, 2016
Help unlock child lock on tv
You need to have child lock code! Maybe has factory default Look manual. Sometimes factory reset overides child lock. Not sure about your model though.
PLEASE COMMENT, I'M INTERSTED TO KNOW
May 06, 2015 | Panasonic TH-42PV8H 42 inch MultiSystem...
Hi, Approximately eighteen months ago, I purchased a 42 inch plasma Panasonic television model number: TH-42pz77u) but Saturday night, the television turn off and have five blinking red lights. Then we...
The 5 blinks on the LED means that the main logic D board is defective and will need to be replace to fix the TV.
Check this site to find replacement parts to fix your plasma if you intend to DIY.
Let me know if you need further assistance.
Jan 15, 2011 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic TH-42PZ80U doesn't turn on. 10 time blinks
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Oct 27, 2017 | Panasonic Viera TH-42PZ80U Plasma TV
Red Blinks - No Power
2 blinks is one of the power sources not coming up. most likely thje power board,but a short on a periphael board can mimmick. Only a Panasonic auth service should be used and expect a repair of $200 to $400. Since the set is not very old,call the panasonic number in your book......they will give you a case number and in some instances may cover it!!
Jun 04, 2010 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
My panasonic plasma tv has some error! the red led bliks 7 times then pause and then 7 blinks again. what i can do? panasonic th-42pz70e
Panasonic sent a repairman out with the correct part after telling them about the seven blinks. The unit was out of warranty. They rock. Call 800-211-7262 or 800-524-1448 1
Sep 12, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
3 months ago Led blinks 7 times now Led blinks 6 times
Sorry to hear that. You could fix it with Best Buy or the warranty service repairman recommended by Panasonic.com
I have a client that had used one of the panasonic repairman to fix the same problem that you have about a year ago,the TV is good ever seen.
I am in the A/V installation business, my recommendation(Pioneer Kuro Plasma TV or Sharp LCD.)Very good track records from my clients.
solutiondoct
Nov 03, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Sep 16, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
TH-42PX77U wont turn on with remote....?
Panasonic uses the flashing of the power LED as a guide for trouble shooting their sets when no image is visible. So if the power LED blinks 3 times then the D board is defective. Basically its the main control board. It needs to be serviced.
Nov 29, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic TH-42PV8H 42 inch MultiSystem Plasma TV Logo
132 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
