You have to reset everything the cable box,the TV by unplug,replug it an hour later.Let the tv reset itself back to factory setting,and the cable box to upgrade it software.If it work that great, if otherwise you need to change the cable box, I hope this will help to solve the problem....
HTC Phones are known for short battery life if you are using it only expect 2-4 hours
If you are not using it at all and have turned off wifi 3g the screen music and background apps and don't make any calls/txts expect as many as 18 hours.
That's a pretty short time. If your phone has bluetooth and you don't use it, find your bluetooth settings and turn it off. This will help save battery life. Also if you have the backlight set for long periods you might want to decrease the amount of time the light stays on after touching a key.
the problem is with the control panel of your tv...make sure your remote doesnt have any part in this...just remove and the batteries and check if the channels still are changing.....see if the onboard switch for channel changing is stuck ?..if stuck u can use homemade tools to pull it back......if your tv is within your gurantee period...just giv a call to customer care....if not u can take it to a local repair shop...there is nothin that u can urself do to make it right ...sorry....for further info contact at
the hlr series had a few problem with intermittent turning off. one was the lamp door cover switch, the other was the thermostat.. neither one is very costly and a good tech should be able to replace bothe parts at the same time..
