Question about Pulsar Watches
I have a Pulsar watch need to change to day light saving time
I can't seem to change time on my Pulsar watch and I need to change to day light saving time
Bill Boyd
    Top Expert:
  • Pulsar Master
  • 53,816 Answers
Just put the hour hand forward or back 1 hour
Posted on Mar 15, 2016
I have a Pulsar Qartz railroad approved watch and don't know how to change day and date! Can you help me?
Hi fatmike19,
You can download the manual for your Seiko Pulsar Watch on this link. The instruction on how you will change the day and date is there.
Hope it helps.
Thank you for using Fixya.
Apr 07, 2011 | Seiko Pulsar watch
Pulsar Ladies date watch, approx. 5years old. When battery changed, watch works properly for few days, then it stops. What can the problem be? Does it need cleaning and if so how much?
It is possible the battery was weak to begin with, have the battery replaced to see if that will cure the problem because this a much cheaper way than the alternative.
Dec 31, 2010 | Seiko Pulsar watch
Fix date n month on wrist watch
mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
Jul 19, 2010 | Pulsar 5117 Wrist Watch
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
Jul 08, 2010 | Seiko Watches
I have a pulsar chronograph 100m the time keeping seems to be ok but, the buttons for stop watch, when stopping the sec,1/20 etc hand are not returning to zero. can u help. richard
Thanks for using Fixya.
Try this: pull out crown to the first click, then push and hold button at 2 o'clock. When the hand is adjusted to the desired time, push the crown back in.
If this do not work, do the same using the button at 4 o'clock.
Good Luck and have a nice day.
Apr 27, 2010 | Pulsar Watches
Can't seem to get AM & PM set properly
Had Pulsar analog watch. Couldn't set either day or date properly due to being unable to signify AM or PM. When days changed one or the other would be 12 hours off.
""googled" adjusting Pulsar watches" and found site which explained how. You set day of week and date to previous day and date and then move watch time ahead until day and date are correct. Then set watch time. Seems to work.
url: www.pulsarwatches.com.au/manuals_pdf/94_1.pdf
Apr 22, 2008 | Watches
Time keeping.
Check in the instructions about the time zone setting and that the feature for auto day light savings are turned on.
If you go to the manufacture site for many of these watches, they have downloadable PDF instructions. They also have service centers that can give support.
Jerry G.
Mar 18, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Pulsar Mens Wrist Watch
I have a similar solar modle Ive had since 1995 , about 4 years ago it started loosing time and the second hand started double ticking. I sat it down out side on a cool summer day for the hole day in the bright sun and never have had a problem since. knock on wood! It was also runover by a car last year and still works good. I wont ever get ride of it. Hopefully this helps u guys out
Jan 30, 2007 | Pulsar PXF216 Wrist Watch
Watches Logo
218 people viewed this question
Top Pulsar Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
ray gallant
Are you a Pulsar Watch Expert? Answer questions, earn points and help others
