well could be two things. either your transmission has crapped out on you. or you have a shifter linkage issue. which means when the car is in park its not really in park. try this. move the shifter and see if the car moves in a different gear then what it says it is in . so if it moves in neutral it could be drive and reverse is neutral. if it does not reverse at all. time for a new trany is my guess.
this hydrostat drive tractor is designed to max at 5.5 mph forward, 2.5 in reverse, check linkage at pedal if you dont think your achieving those speeds
Hi, remove the battery and battery support tray and clean all debris from around the hydrostatic drive, fan and cooling fins. Your problem is caused by the hydrostatic drive overheating. Hope this helps, regards Phil
There are three motors. The one motor moves the seat forward and reverse, one for up and down and one for the tilt. So you may have a problem with the switch. It's possible the switch contacts inside have worn out.
