SOURCE: IR 2870
The waste toner container is full. the front cover of the machine (the one with the Canon logo on it) must be removed. behind you will see a big white plastic bottle. Remove the bottle, empty the contents into the bin, wipe it off, and refit all removed parts. Finally restart the copier.
SOURCE: canon ir 5000 erorr E 000004 - 0000
.it is an heater lamp problem
or
thermostat is a problem
SOURCE: E000821-0002 ERORR WHY R U
these means that copier is detected too much waste toner in cleaning blade assy.
Book says:
Clogging of toner inside the cleaner has been
detected with reference to an abnormal rise in the
cleaner thermistor.
Try to:
- Remove the waste toner from inside the cleaner.
- Replace the air filter of the heat discharge fan.
and I would also recomend to check waste toner stiring "snail" and waste toner container.
Hope that helps!
For service manual you can contact me on [email protected]
SOURCE: I can't using my
I see the service manual the 5000 eror is not exist,sure is not error 5100 or 5C00 ?
