Question about Franke Coffee Makers & Espresso Machines
How do I unblock the steam wand on my franke flair coffee machine.
Posted by Isaac senatsi on
ray gallant
    Top Expert:
  • Franke Master
  • 69,252 Answers
Possibly with a small stainless wire .
Posted on Mar 15, 2016
No milk and steam dispensing from Franke Flair coffee machine
I am a Franke technician. After and possibly during the descale, because probably you haven'nt done it in a long time, steam was able to escape through the fittings as the limescale damaged the silicone rings beforehand. The steam damaged the klixxons or the thermoblock itself. You will need one of us unfortunately....
Feb 17, 2018 | Franke Coffee Makers & Espresso Machines
My franke flair coffee machine will not power up
the two main reasons for this are the on off switch located on the back of the machine is switched off. the other is the flap to the grinders is not correctly fitted. other than this an exporative visit by an engineer may be required. there are two mains fuses situated by the cable inlet behind the rear panel.
Apr 26, 2014 | Franke Flair Espresso Machine with...
Franke flair
Where can I buy new seals or a whole new drop tray please
May 15, 2013 | Franke Flair Espresso Machine with...
I have a franke flair coffee machine when you switch it on it reads on the panel please wait and will not complete the switch on. Any help thanks
DESCALING The Saphira has an integrated descaling program. The procedure takes about 60 minutes. Once started, the descaling procedure may not be stopped. • When acid-containing descalers are used, immediately remove any splashes or drops on sensitive surfaces, particularly from natural stone and wood surfaces. Also, take the appropriate safety precautions. • Turn off the Saphira by pressing the "ON/OFF" button. • Press the button "Descale" until an acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: INSERT AGENT IN TANK • Display: PRESS DECALCIFYING Dissolve 2 DESCALING tablets completely in 2.5 cups of water in a vessel and pour the mixture into the empty water tank. Place a sufficiently large container under the steam tube and the coffee delivery outlet. • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY (Fig.1) • Display: FILL WATER TANK • Display: PRESS DECALCIFYING • Press the Descale button • Display: UNIT DECALCIFYING • Display: PLEASE WAIT • An acoustic signal is heard. • Display: EMPTY DRIP TRAY • Display: CLEAN CONTACTS
Good Luck [email protected]
Dec 22, 2010 | Franke Saphira Espresso & Coffee Maker
Saeco S class Incanto Classic was working, but now no steam at all. The pump sounds like it is trying to pump, but cuts out after a coupl of seconds, hot water light comes on, red water light flashes, and...
Check the end of the steam wand and parnello, if both are clear, then descale machine, that might unblock the tubes feeding the booster boiler and the steam wand if it doesn't then you will have to do it manually.
Mar 06, 2010 | Saeco Incanto Classic Espresso Machine
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
Low pressure from steam wand
It sounds like calcium has built up in the machine. Try running pure vinegar through the machine a couple of times. Hopefully that will clean out the calcium and it will start working again. I had the same deal with a coffee pot that took forever to run the water through. After two sessions of vinegar it worked like new
Jul 01, 2017 | Breville ESP8XL Espresso Machine
If you need a Franke trained coffee machine engineer to repair, service or for training, i can be there within 24hours, Email me for any questions great prices! 50mile radius of CV21 3SH
Hi
I have just bought a Franke Flair coffee machine second hand. It looks like new and the seller said it was in good working order - however it does not have the grinder blocker and I think we need one. I wouldn't mind also getting the once over from an expert and then maybe some kind of ongoing contact should we have problems with it. What are your rates?
Jun 15, 2009 | Franke Saphira Espresso & Coffee Maker
Coffee Makers & Espresso Machines Logo
360 people viewed this question
Top Franke Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Dennis
Are you a Franke Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
